1970-2 Dart/Demon Fender Extension Attaching Hardware #2694417
09/04/19 04:46 PM
09/04/19 04:46 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
What was originally used to attach the front fender extensions on a 70-2 Dart/Demon.I have the later 72 version using the threaded studs.Was a flat or lock washer used along with just a regular hex nut? Thanks for any help
Re: 1970-2 Dart/Demon Fender Extension Attaching Hardware [Re: 44D6PAKCUDA] #2694513
09/04/19 11:13 PM
09/04/19 11:13 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Its called a pal nut, this isn't likely the correct size but it has a pic for reference
Pal nut
eBay-cdwmotorsports
Re: 1970-2 Dart/Demon Fender Extension Attaching Hardware [Re: 44D6PAKCUDA] #2694514
09/04/19 11:16 PM
09/04/19 11:16 PM
Martinsville, IN
Martinsville, IN
Are your fender extensions pot metal or a fiberglass type material? I ask because the ones on my 72 Demon were metal and the replacements I have are some sort of fiberglass/plastic stuff and I believe they are from a 70 Dart. My 72 Demon ones were just a stud and not at all threaded.
eBay-cdwmotorsports
Re: 1970-2 Dart/Demon Fender Extension Attaching Hardware [Re: cdwmotorsports] #2694603
09/05/19 08:43 AM
09/05/19 08:43 AM
The ones on the car when I got it were part #3574116-7 (potmetal) and have the threaded studs.I bought a pair of NOS ones,#3573788-9 (potmetal) and they have the smooth,molded in studs that I assume would use the pal nut like you showed.These are also listed in the parts book as up to 12/01/71 and I also bought a pair of NOS #3574148-9 that the book shows after 12/01/71 (I have not received these yet,but will post what material they are made of) My car was late 72 production (April 72) so according to the book,my car should be this last number...but
Re: 1970-2 Dart/Demon Fender Extension Attaching Hardware [Re: 44D6PAKCUDA] #2694776
09/05/19 07:29 PM
09/05/19 07:29 PM
Martinsville, IN
Martinsville, IN
If you go look at this listing you can see the nuts that the non threaded stud use. I don’t have any information on the threaded ones sorry.
Look at this on eBay
MoPar 70 71 Dodge Dart Demon Fender Extensions With Chrome 1970 1971 1972
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F123892192534
eBay-cdwmotorsports
Re: 1970-2 Dart/Demon Fender Extension Attaching Hardware [Re: cdwmotorsports] #2694859
09/06/19 03:25 AM
09/06/19 03:25 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I’ve been looking for quite some time for the fiberglass extensions which is 1970 only. In ‘71 they were pot metal with molded in studs and ‘72 they were pot metal with removable studs.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: 1970-2 Dart/Demon Fender Extension Attaching Hardware [Re: mopardude318] #2695096
09/06/19 11:48 PM
09/06/19 11:48 PM
Bradford, Ontario
Barrelhouse Offline
Barrelhouse  Offline
Bradford, Ontario
My 1972 Demon has a build date of 9/71 Sept 1971 it has the metal fender extensions with moulded in studs.
