Re: Starting to work on the Duster
[Re: AndyF]
#2694490
09/04/19 09:25 PM
09/04/19 09:25 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I kicked everything MSD other than my crank sensor bracket off of my car when I went EFI because I had experienced reliability problems. That being said I like the clean and simple setup those relay setups offer, and they are solid state on top of that.
68 Barracuda Formula S 340
[Re: AndyF]
#2695194
09/07/19 11:51 AM
09/07/19 11:51 AM
Posts: 19,426 north of coder
moparx
andy, those longacre tools are pretty accurate. i have a similar tool [i can't remember the name, but it was one of the first ones of that design put out], and have used it a lot. i bought that, plus a couple of others, and i have had great luck aligning my stuff, and no goofy tire wear. there are no good places around here to get an alignment, thus my delve into these tools.
[Re: AndyF]
#2695595
09/08/19 09:59 PM
09/08/19 09:59 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
Toe is easy to do with a tape measure and camber can be guessed at pretty well with a straight edge and bubble level but caster is the tough one. At least on a IFS. Caster wouldn't be too hard with a straight axle I suppose.
I think a person could design a fixture that measured caster directly off the knuckle but it would take some clever thinking. With a spool the car is already hard to turn, so dialing in as much caster as you can just makes it ride better down the track.
[Re: AndyF]
#2701010
09/26/19 05:40 AM
09/26/19 05:40 AM
Posts: 10,029 MN
JERICOGTX
MN
Car is looking good Andy.
69 GTX
68 Road Runner
[Re: AndyF]
#2701093
09/26/19 11:44 AM
09/26/19 11:44 AM
Airwoofer
Huntsville, AL
I ended up buying a repo air grabber setup for the car. I decided I liked the way it looked so I plunked down the money. You ought to talk with Hemi denny about some of his LCAs. A lot lighter.
[Re: second 70]
#2701548
09/27/19 08:37 PM
09/27/19 08:37 PM
Posts: 31,044 Oregon
AndyF
That air cleaner top would look great painted to match the valve covers. Just would have to get a filter with a black seal. If I change the color on the air cleaner I'll probably go black, Maybe make the valve covers black too. I'm going to leave it orange for now since people expect an Air Grabber top to be orange but if I get tired of orange I'll probably powder coat it black. I don't think I'd go with the turquoise color.
[Re: mopar dave]
#2701569
09/27/19 09:38 PM
09/27/19 09:38 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
Very nice work! attention to detail is off the charts!!
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
