Page 125 of 159 1 2 123 124 125 126 127 158 159
Re: Paint job on a budget!? CONTINUED..page 44........ #26938
02/18/07 01:19 AM
02/18/07 01:19 AM
Just a quick photo drop. The image is highly compressed so it may be fuzzy. Just wanted to show the kind of coverage I've gotten so far with 8 layers of rolled on paint with a dual light wetsanding after every other layer was applied.
I'm still planning on using Briteside for the final paint job, but at this stage of things my only goal was to get all of the bare metal covered and get the car uniform in color.
Re: Paint job on a budget!? CONTINUED..page 44........ #26939
02/18/07 02:07 AM
02/18/07 02:07 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I'm not sure why people are still using Rustoleum. Brightside has a better shine. Yes, Brightside or other marine poly is more expensive but you can most likely buy all the paint you'll need, with some leftover, for under $100 (3 quarts at $30 each).
Re: Paint job on a budget!? CONTINUED..page 44........ #26940
02/18/07 02:10 AM
02/18/07 02:10 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Phantasm - that's a good idea. That's what I ended up doing, but not by plan. Using rustoleum as a base layer will have benefits including needing to buy less Brightside (as long as you're using brightside of a similar color as the rustoleum of course), and getting to practice, sand down messed up spots, and practice some more. And perhaps better rust resistance. Plus rustoleum can be sprayed into engine compartments and door jambs where shine isn't a priority.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26941
02/18/07 03:14 AM
02/18/07 03:14 AM
I'm finding when I'm rolling it on it will instantly look like orange peel and wont go on uniformly. Even after leaving it sit for a few minutes it doesn't seem to self-level fully. I've tried mixing it thinner and thicker and have found it doesn't roll on easily when thin, but creates more orange peel when thicker.
I've just applied my forth coat after wet sanding after the second coat, and I reckon another two coats and the cover will be even.
Does anyone have pictures of each stage? Like after the very first coat then after the 2nd coat etc.
I will take pics after I'm done paining the bonnet (hood to you guys) and fenders.
Re: Paint job on a budget!? CONTINUED..page 44........ #26942
02/18/07 10:38 AM
02/18/07 10:38 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
It should roll on easy when thin-- but you have to apply a thin coat of it. When I was painting with the Rustoleum, I would make medium thin mixture, but when wetting the roller I would push most of it out. Id push down hard on the tray to get most of the paint out. Then Id push down firmly on the car, and it would leave a thin coat and there was little if any orange peel.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26943
02/18/07 12:24 PM
02/18/07 12:24 PM
How good does Rustoleum work over rust ?
mostly asking about spraying it on the underside ,
the frame rails , underside of the floors and inside of wheelwells ,
the metal is not rusted thru , just has some light surface rust , I will knock down the flacky stuff,
do I need to rough up the surface or does Rustoleum have some "bite" when its put on ?
I just think that covering the bottom will make the car look better and hopefully keep it from rusting further....
I planned on using a dark grey primer color Rustoleum.
Beaulieu
In Southern California
Re: Paint job on a budget!? CONTINUED..page 44........ #26944
02/18/07 03:06 PM
02/18/07 03:06 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
I did the insdie of my trucks bed with Rustoleum's rusty metal primer the brown color stuff, used it straight out of the can no thinning, goes on flat and level, I used both a roller and a foam brush can't tell which was done with one or the other.
I'd guess all primers would do the same thing.
I spent a hour or better with a wire wheel brushing the entire bed area, blew it out with air then wiped it down good before primer, I still want to roll on something like Herculiner and see how it holds up.
Re: Paint job on a budget!? CONTINUED..page 44........ #26945
02/18/07 09:17 PM
02/18/07 09:17 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I painted an engine pulley which had some surface rust. The rusty areas took more paint to cover. I am not too worried about the pulley rusting through, but I am not sure what rust does underneath paint. Hopefully nothing but if I could I'd take off all the rust I reasonably could.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26946
02/18/07 09:59 PM
02/18/07 09:59 PM
I thought about Brightside and looked at it, but it didn't have the color I wanted (brown), which Rustoleum does.
Re: Paint job on a budget!? CONTINUED..page 44........ #26947
02/18/07 11:03 PM
02/18/07 11:03 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
There are other marine polyurethanes out there, petit easypoxy for example. they list some browns, but youd have to check out a color card.
http://www.pettitpaint.com/catalog_browse.asp?ictNbr=45
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26948
02/18/07 11:22 PM
02/18/07 11:22 PM
Can anyone recommend a hardner of some type that would be compatable with Rustoleum?
I am ready to apply my last coat and want it to have maximum hardness. The prior coats did not provide the ability to keep from marring with a simple rub of my fingernail. And the prior coats have had ample time to dry since the last coat was put on in September.
Any suggestions/help would be appreciated.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: kenzo42] #26949
02/19/07 10:21 AM
02/19/07 10:21 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
Does anyone have experience or insight on multiple colored panels on a car? Would each panel come out a different color if I were to use this method w/ Brightside? Thanks.
Just remember that each coating of Brightside ( or even Tremclad/Rustoleum) are almost translucent when you paint them on. It takes multiple layers to eventually build up a solid uniform color. So if you start with a car of many colors... you will be able to see those variations for at least four to six coatings.
So there are two ways to nail down a uniform paint job on a car of many colors....
a ) Yes... as you build up your layers of Brightside paint eventually all panels will end up at the same color and with little difference between them...
OR
b ) a smarter move would be to lay on one layer of the Brightside primer... to give yourself one uniform base color on which to start laying your Brightside paint. The Brightside primer has the highest concentrations of 'solids' and hence it can lay down a uniform color in less coats ( 1 or 2 at the most ).
In the long run I would say that giving the car a uniform primer color to begin with, will save you time and money when laying on the color coat of Brightside.
Re: Paint job on a budget!? CONTINUED..page 44........ #26950
02/19/07 10:36 AM
02/19/07 10:36 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
Well... as per my failed experiment to create a blood red... it turned out that Brightside Fire Red PLUS Brightside Black EQUALS brown....
Depending on the amount of red you add to a majority of black... your color range can go from clay pottery brown to a fairly deep mahogany brown....
Re: Paint job on a budget!? CONTINUED..page 44........ #26951
02/19/07 04:08 PM
02/19/07 04:08 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I am not sure how that would work with a roller though. And its as toxic as any other paint hardener.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26952
02/19/07 05:16 PM
02/19/07 05:16 PM
Bakersfield, CA
K
kenzo42 Offline
kenzo42  Offline
K
Bakersfield, CA
My buddy has a new Porter Cable 7336 (not refurbished and box still wrapped in plastic wire ties) for sale if anyone is interested. He said $95 shipped from Vacaville, CA.
Please delete if not appropriate for this forum. I didn't see a for sell section, and I thought this would benefit some of us rollers since Marq got such good results w/ this.
PM me if interested!
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26953
02/19/07 10:08 PM
02/19/07 10:08 PM
Exit1965
Thanks for the recommendation. That gives me something to look for.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26954
02/20/07 11:29 AM
02/20/07 11:29 AM
Exit, thanks for the headsup on the hardener.
I got the spec sheet and it states:
"INSTRUCTIONS FOR USE:
Add full contents of this package to 1 gallon of oil-based enamel... Mix well initially and occasionally for the next 30 minutes to fully activate. Begin using after the 30 minute activation period has passed. Shelf life is 8 hours after which mixture should be discarded."
Their tech group says that it does not effect the durability of the paint, and they could not say how long the drying time would be reduced.
I wonder how the self-leveling characteristics of the Rustoleum Professional mixture would be affected. Has anyone ever used the Valspar Hardener (18-4625)?
Re: Paint job on a budget!? CONTINUED..page 44........ #26955
02/20/07 11:59 AM
02/20/07 11:59 AM
that pretty much blows the idea of doing the thin coats , also will stirring it so much put air bubbles in it ?
Beaulieu
Re: Paint job on a budget!? CONTINUED..page 44........ #26956
02/20/07 03:25 PM
02/20/07 03:25 PM
Hello!
First - 69chargeryeehaa - thank you. This is the most compelling thread (because of your input) that I have ever read.
I know someone - family member - inside Sherwin Williams (a higher up) and I asked him specific questions about their paint. He does not know about this thread or why I asked about paint.
Q: Doing some research, like to know about Sherwin Williams paint - what do they make equivalent to "Rustoleum Pro" ?
A: Best product is called Rust Tough. Direct to Metal, excellent gloss level, impact resistance & rust protection. You can buy this from Wal-Mart. This is the same product we sell to our industrial customers. The aerosol uses a patented Krylon nozzle - called a FanSpray - that is fantastic!!
http://www.krylon.com/main/product_templ...product_details
Q: So it is equivalent to Rustoleum Pro or Rustoleum "Stops Rust" ?
A: Yes. Similar but better. Spray cans should match bulk (gallon cans).
Q: So Rust Tough is better than Rustoleum Pro ?
A: Yes. We compete against Rustoleum every day. I am very confident that Rust Tough will out-perform Rustoleum.
I thought this info might be of interest to reader's of this thread.
To see colors for Rust Tough Enamel click on Can this page: http://www.krylon.com/main/product_templ...product_details
Re: Paint job on a budget!? CONTINUED..page 44........ #26957
02/20/07 03:28 PM
02/20/07 03:28 PM
I went by the local auto paint supplier today and picked up a pint of Synthetic Enamel Hardner - E297. Labeled under Duragloss Refinish Products.
This was what he had on the shelf at this time. Says he sells whatever his supplier sends him. They all work the same he said.
The ratio of hardner to paint is 1 to 8 also. Not much in the way of instructions. Just stir in slowly. I think he mentioned a working time of around 4 hours.
I have several coats of Rustoleum Professional on my fiberglass dune buggy. However, I could not achieve the hardness others have reported.
So I decided to give it one last coat with the hardner included. Hopefully this will work or I will be the one in one million who did not have success with this paint process.
Looking for any last tips before the final coat is applied and depending on the outcome, the cheering or crying begins.
