TQ float bowls #2693987
09/03/19 02:22 PM
09/03/19 02:22 PM
Nova Scotia, Canada
Tech junkie Offline OP
Nova Scotia, Canada
Anybody find a glue that will actually reattach the little fuel wells under a thermoquad float bowl? I've tried seal-all which is supposed to work in a gasoline environment but in time just turns into a mess.
Re: TQ float bowls [Re: Tech junkie] #2694004
09/03/19 03:36 PM
09/03/19 03:36 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Loctite 401, sold at industrial supplies like Fastenal, Granger, etc.
VERY important! It has to be fully cured before fuel contact, I suggest 24-48 hours. Also, don't reassemble the carb or otherwise encapsulate the glue while curing, it needs to vent to open air while curing.
Re: TQ float bowls [Re: ScottSmith_Harms] #2694016
09/03/19 04:35 PM
09/03/19 04:35 PM
Nova Scotia, Canada
Nova Scotia, Canada
I'll try it. If this works, you've helped a few old carbs back from the grave. Thanks!
Re: TQ float bowls [Re: Tech junkie] #2694236
09/04/19 08:51 AM
09/04/19 08:51 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
I have used regular epoxy glue ( reading on specs is oil products resistant of course ) and that has worked for me.
Re: TQ float bowls [Re: ScottSmith_Harms] #2694283
09/04/19 10:55 AM
09/04/19 10:55 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
X2 ! . . . .
