Re: ZF 8 Speed
[Re: MattW]
#2698448
09/17/19 01:25 PM
09/17/19 01:25 PM
Posts: 8 IL
wish4hemi
IL
Re: ZF 8 Speed
[Re: MattW]
#2701624
09/28/19 04:21 AM
09/28/19 04:21 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Less than 200 lbs? The A-8 ? Have you actually seen one of these? They are huge. Is that with the converter and fluid? How could they be around the same weight as a 727 ??
Re: ZF 8 Speed
[Re: Kern Dog]
#2701700
09/28/19 11:55 AM
09/28/19 11:55 AM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
Re: ZF 8 Speed
[Re: Kern Dog]
#2701769
09/28/19 03:47 PM
09/28/19 03:47 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Less than 200 lbs? The A-8 ? Have you actually seen one of these? They are huge. Is that with the converter and fluid? How could they be around the same weight as a 727 ?? Less converter. Nor sure about fluids. Better design I guess. If you can control it with an aftermarket controller or manually like the guy did in the video, then you have one heck of a trans for a swap. Matt
Re: ZF 8 Speed
[Re: MattW]
#2701855
09/28/19 10:11 PM
09/28/19 10:11 PM
Posts: 2,255 IL
furious70
IL
I keep posting in these TF-8 posts - the trans is 9" tall at the rear mount. It's a very different size and shape from a 727. FYI for all who've never seen one, it will take a lot of tunnel surgery. Not that it isn't a great trans, but it's going to be a lot more work than making a 518 fit.
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: ZF 8 Speed
[Re: roadrunninMark]
#2775024
05/16/20 07:25 AM
05/16/20 07:25 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
These transmissions work so well in the modern cars because of how integrated the controls are into the whole car. We have an 18 Durango R/T and I really like the how the 8 speed works but I think it would be really hard to do from the aftermarket.
68 Barracuda Formula S 340
Re: ZF 8 Speed
[Re: Bad340fish]
#2778774
05/27/20 03:45 PM
05/27/20 03:45 PM
Posts: 9,719 Home
SRT6776
Home
These transmissions work so well in the modern cars because of how integrated the controls are into the whole car. We have an 18 Durango R/T and I really like the how the 8 speed works but I think it would be really hard to do from the aftermarket. Its just a tune you put into them. Not sure if the 8-speeds are ZF tuned or FCA tuned, I know FCA has had troubles with their own tune in the ZF9 (FWD) used in the jeep cherokee with harsh shifts etc. Word is they called up ZF to help and now its fixed. Either or, it may work with a base tune from 6.4 car or the aftermarket can tweak it from there. I don't think it'll be too difficult.
Re: ZF 8 Speed
[Re: MattW]
#2939626
07/03/21 09:51 PM
07/03/21 09:51 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Has anyone heard about this company?
HTG Tuning? Apparently they have a ZF standalone controller. Yeap used HTG to swap a 8sp out of a 2015 Ram 4x4 in to a 77 Ramcharger, took awhile to get it from over the pond to here in Eastern PA.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
Re: ZF 8 Speed
[Re: MattW]
#2939627
07/03/21 09:55 PM
07/03/21 09:55 PM
ric3xrt
Trumbauersville PA
That video show him running the trans with a cheap controller he made. Have no idea if it is true or not but seems real. Fiat need to jump on this or even ZF out of Germany. They used this same trans ( Basic setup) with upgrades in the GT4 class at Neuenburg. I believe they dropped the converter for a clutch. This trans is less than 200 lbs and can handle up to 750 ft lbs I think in the hp90 trim. Googled 8 speed and got GM stuff engine and transmission controllers for swaps. JESUS they R quick!!!!! Irony when you think about it, for a while there swapping the 4l80e was the hot ticket for Mopar guys now swapping the ZF trans is the hot ticket for GM guys....Ohhhh the Horror or it all
Re: ZF 8 Speed
[Re: ric3xrt]
#2942576
07/13/21 10:36 AM
07/13/21 10:36 AM
MattW
Ontario Canada
HTG Tuning? Apparently they have a ZF standalone controller. Yeap used HTG to swap a 8sp out of a 2015 Ram 4x4 in to a 77 Ramcharger, took awhile to get it from over the pond to here in Eastern PA. Stop teasing us!!! How does it work?? Would love to see a detailed report on this.
