Tire Stagger on Drag Slicks? #269340
03/28/09 09:29 AM
03/28/09 09:29 AM
On the south side of Nowhere
S/ST 3040 Offline OP
I just took delivery of my new slicks in an effort to get the
car, at least rolling and ready for a drivetrain. Uninflated,
measurements appear to be in error but, SOMEBODY is getting
a phone call on Monday.
I'm sure it will all work out but, why would somebody pull a
"pair" of tires that are marked this far apart?
Re: Fastback Barracuda...........Oval Track?? [Re: S/ST 3040] #269341
03/28/09 09:32 AM
03/28/09 09:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just looking at them the sides seem way off... where
did you get them
Re: Fastback Barracuda...........Oval Track?? [Re: MR_P_BODY] #269342
03/28/09 09:42 AM
03/28/09 09:42 AM
did you get them
They are not as far off as the picture makes them appear. (without being mounted)
My problem is, I'd think they could still get a closer match if they have several to pick from.
I don't particularly care to be stuck with them if there's an 1" difference, after they get mounted.
Re: Fastback Barracuda...........Oval Track?? [Re: S/ST 3040] #269343
03/28/09 09:46 AM
03/28/09 09:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
did you get them
I hear ya.... specially that they are measured and
they sent them out that far off
Re: Fastback Barracuda...........Oval Track?? [Re: MR_P_BODY] #269344
03/28/09 10:06 AM
03/28/09 10:06 AM
SD USA
neonic Offline
neonic  Offline
SD USA
Are you sure that is the uninflated measurements? I had a set of Hoosiers that were numbered off like that. When I called them they said that number means nothing to consumers. Its a 60 psi hot inflation check that they perform. When I mounted them and set air pres. they were the same size.
Re: Fastback Barracuda...........Oval Track?? [Re: neonic] #269345
03/28/09 10:18 AM
03/28/09 10:18 AM
hmmmm.............I'm sure their measurement was inflated.
My check, uninflated only shows 1/2" difference. (94 1/4"-94 3/4")
They should be 97 1/2"-98" anyway.
I'll be sure the tire manufacturer and I have an understanding
before these get mounted.
Re: Fastback Barracuda...........Oval Track?? [Re: S/ST 3040] #269346
03/28/09 04:04 PM
03/28/09 04:04 PM
Lexington South Carolina
johnnyp Offline
johnnyp  Offline
Mount them .Fill them to about 35 psi and put them in the hot sun they will come with in a 1/4 to a 1/2 inch of each other.
Re: Fastback Barracuda...........Oval Track?? [Re: johnnyp] #269347
03/28/09 04:07 PM
03/28/09 04:07 PM
Hot sun??? I wanted to put them on the car before June.
I was counting on them being 31" in diameter too.
At least Phoenix says their 13" x 31" are actually 30.6"
Post deleted by Defbob [Re: johnnyp] #269348
03/28/09 05:53 PM
03/28/09 05:53 PM
Re: Fastback Barracuda...........Oval Track?? [Re: S/ST 3040] #269349
03/29/09 01:25 AM
03/29/09 01:25 AM
If I was you I would send them back and get a match set to start with , within 1/4 inch is my preference Check the tire numbers(seriel number and mold #)to mkae sure you get a match set
Re: Fastback Barracuda...........Oval Track?? [Re: Cab_Burge] #269350
03/29/09 08:31 AM
03/29/09 08:31 AM
They are Mickey Thompson tires that I bought through Summit.
I called Summit Customer Services shortly after recieving them.
They told me, the slicks are sent to them in pairs and they ship
them out the same way.
There's a note on the slicks (label) to call M/T Tech line if they
are more than 3/4" difference in circumference.
I don't expect every single tire to come out identical but, feel
if they go to the trouble of measuring every one.............they
should be matched much closer, especially for the price.
Re: Fastback Barracuda...........Oval Track?? [Re: S/ST 3040] #269351
03/29/09 08:45 AM
03/29/09 08:45 AM
Q
Quicktree Offline
Quicktree  Offline
Q
thats why you buy slicks from Harlow tire....
Re: Fastback Barracuda...........Oval Track?? [Re: Quicktree] #269352
03/29/09 08:49 AM
03/29/09 08:49 AM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
Got that right !!
Re: Fastback Barracuda...........Oval Track?? [Re: VernMotor] #269353
03/29/09 09:00 AM
03/29/09 09:00 AM
Phone number please?
If I can't get this worked out to my satisfaction with a phone call
tomorrow, Summit can send a call tag for these.
Re: Fastback Barracuda...........Oval Track?? [Re: S/ST 3040] #269354
03/29/09 09:17 AM
03/29/09 09:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been buying from Harlow for the last 3 sets
1849 N Wayne Rd
Westland, MI 48185
(734) 722-0061‎
(734) 722-0052‎
Re: Fastback Barracuda...........Oval Track?? [Re: MR_P_BODY] #269355
03/29/09 09:22 AM
03/29/09 09:22 AM
Thanks Mike.
Re: Fastback Barracuda...........Oval Track?? [Re: S/ST 3040] #269356
03/29/09 01:28 PM
03/29/09 01:28 PM
Contact M/T (Cooper tires) and complain to them, ask them to have Summit contact you about replacing them. Drag tires that are that far off are dangerous in a car with a spool, you may want to mention that to M/T rep that you speak to As far as the Summit persons comment on pairs of tires I'm sure every pair is bundled together so they don't get seperarted before the customer recieves them the last I heard is that Summit buys tires from Cooper and M/T by the railroad car loads
Re: Tire Stagger on Drag Slicks? [Re: S/ST 3040] #269357
03/29/09 02:18 PM
03/29/09 02:18 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
I got a set of M/T's from summit a couple years ago that had a 7/8" difference. I called summit's customers service and and he told me up to 3/4" difference would be fine. When I explained that the pair I received showed 7/8" difference he said that he'd send another pair and a pick up tag . The very next day , the new set shows up that had a 7/8" difference between them, but they were the two exact sizes that I had previously received , so I could choose between which size that I preferred to run.
Re: Tire Stagger on Drag Slicks? [Re: super451b] #269358
03/31/09 02:42 PM
03/31/09 02:42 PM
Well, I called M/T Tech yesterday and was told they do not ship
slicks to Summit in pairs but, in bulk. I sort of figured that.
Next call was back to Summits Customer Service. Apparently the
first guy I called Saturday just passed the buck and hung up. No
note was made on my order of my complaint.
I get a different guy this time..........UPS showed up a few minutes
ago with a pair of 97" & 97 1/4" Much Better.
Re: Tire Stagger on Drag Slicks? [Re: S/ST 3040] #269359
04/01/09 01:21 AM
04/01/09 01:21 AM
Thanks for letting us know
