Re: 1/4 mile pass question!
[Re: Wicked49670dart]
#2692123
08/27/19 11:56 PM
08/27/19 11:56 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
Are these radials or bias ply slicks? If radials probably their to low on the pressure, if not radials I would call Hoosiers west (559-405(maybe 408?)4612 or Hoosier factory 574784-3152) and ask them about their recommendations Are the new tires on the same wheels as the M/T where on? If not look closely at the new wheels and their fitment to the axles and brake drums also as well as the pressures
#2692133
08/28/19 12:51 AM
08/28/19 12:51 AM
Posts: 147 AZ
squirrel
AZ
hold the steering wheel still, let the rear end waggle back and forth, and enjoy the ride!
that's how slicks are
You can start with 15 psi and work your way to lower pressure if they spin at that high of pressure.
btw I run 20 psi in the 9x29 slicks on my altered wheelbase chevy. Hooks ok, and less waggling
#2692625
08/29/19 01:58 PM
08/29/19 01:58 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
The swaying is typical of bias ply slicks, regardless of the type of tire is on the front. The only time mine has swayed bad on bias plies was when the pressure was too low. On a heavy car, you'll probably be around 14-15 psi for them to be happy.
So your car only picks up 15 mph on the back half N/A? And then only gained 6 mph at the 1/8 on a 350 hit???? You have some issues going on here.
[Re: an8sec70cuda]
#2692782
08/30/19 01:42 AM
08/30/19 01:42 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
So your car only picks up 15 mph on the back half N/A? And then only gained 6 mph at the 1/8 on a 350 hit???? You have some issues going on here. I agree as I do remember my low 12 high 11 car from the 70's walking some in the traps and I had bias slicks and bias up front. But I have seen mixing radial and bias make it seem even worse as I know it did on my car. Course radial slicks also run more pressure then bias also which can help. I know my 63 is much better with the radial slicks then the bias were and I do run radials up front. But I think you are right as even if I had bias tires up front I believe it would still have walked some in the traps. Because as you stated it is typical some of the bias slick from what I have seen and heard. Ron
