2004 CTD bad MPG #2691804
08/27/19 03:37 AM
08/27/19 03:37 AM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
I just bought a chipper/shredder from a guy. He was driving a pretty nice and well-used 2004 Ram 2500 (edit:fixed) with the CTD. He was saying that the MPG had dropped down to 17 or so and he could not figure out why. Is there any well-known leading suspect?
Trying to enjoy life!
Re: 2004 CTD bad MPG [Re: calmopar] #2691873
08/27/19 10:08 AM
08/27/19 10:08 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Are you sure it’s a CTD? They didn’t put a diesel in a 1500
Abe Lincoln
Re: 2004 CTD bad MPG [Re: dart4forte] #2691874
08/27/19 10:14 AM
08/27/19 10:14 AM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
100% CTD. I think maybe it was a 2500. It was 2WD also.
Re: 2004 CTD bad MPG [Re: calmopar] #2691990
08/27/19 04:15 PM
08/27/19 04:15 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Ok, 2500
Abe Lincoln
Re: 2004 CTD bad MPG [Re: dart4forte] #2691991
08/27/19 04:16 PM
08/27/19 04:16 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Any codes showing, possible lift pump problem. Brakes hanging up. My 01 2500 would get 23-24 mpg on average unless I was towing.
Abe Lincoln
Re: 2004 CTD bad MPG [Re: calmopar] #2691994
08/27/19 04:18 PM
08/27/19 04:18 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
In-town or highway? The '06 4x4 I had would run 16-18 city and 22-24 highway empty (depending on my right foot wink ). Of course, there were those that said I was dreaming and others that did about the same.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 2004 CTD bad MPG [Re: calmopar] #2692207
08/28/19 09:55 AM
08/28/19 09:55 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Also, the sweet spot when cruising the freeway in the 5.9 is around 2000 rpm. That’s about 70 mph. His 2wd most likely has 3.54s. Over 2000 rpm the mileage starts to drop.
Abe Lincoln
Re: 2004 CTD bad MPG [Re: dart4forte] #2692210
08/28/19 10:02 AM
08/28/19 10:02 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
My 02 2500 gets same mileage when empty, 23-24mpg. Mine is 6spd, 2wd . . . uhhh, is fuel filter clogged up ??
Re: 2004 CTD bad MPG [Re: calmopar] #2692305
08/28/19 01:40 PM
08/28/19 01:40 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
Thanks - I'll send over your thoughts to him. Much appreciated!
Re: 2004 CTD bad MPG [Re: dart4forte] #2693329
09/01/19 01:45 AM
09/01/19 01:45 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
His 2wd most likely has 4:10. 3.73 was an option. No 3.54. The sweet spot is keeping it under 10 lbs. of boost.
Re: 2004 CTD bad MPG [Re: Dave Hall] #2693338
09/01/19 07:03 AM
09/01/19 07:03 AM
Guitar Jones Offline
I would look to see if the oil level is climbing. An indication that an injector is leaking fuel into the crankcase.
Re: 2004 CTD bad MPG [Re: Guitar Jones] #2693419
09/01/19 11:32 AM
09/01/19 11:32 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
He can take the vin and run it at the dealer. That will give him the rear ratio. One thing he could do is start running a cleaner through the fuel. It may be a sticky injector. might take awhile. He could drain the fuel filter can, replace the filter and fill with cleaner. Then run the truck.
Abe Lincoln
Re: 2004 CTD bad MPG [Re: dart4forte] #2695609
09/08/19 10:30 PM
09/08/19 10:30 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Check and make sure it doesn't have any boost leaks, it really hurts fuel mileage when you are just pumping air into the engine bay.
Re: 2004 CTD bad MPG [Re: dart4forte] #2696379
09/11/19 02:04 AM
09/11/19 02:04 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The ratio is printed on a sticker inside the glovebox. The fuel filter should be changed every other oil change. I pour the Lucas injector cleaner stuff through mine. Not 100% of the time. My truck seems to like it. I had an injector go bad and it sounded at times like the rods were coming out of it! eek No missing that one. I've seen the videos of them leaking into the valve train area but I never thought my trucks mileage was that bad to check it. shruggy Does this thing have an aftermarket air filter on it?
Re: 2004 CTD bad MPG [Re: Dave Hall] #2696575
09/11/19 02:34 PM
09/11/19 02:34 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I agree on the fuel filter. I change it spring and fall. I fill the canister with a cleaner. 285k and running great, knock on wood!!
Abe Lincoln
Re: 2004 CTD bad MPG [Re: Dave Hall] #2696626
09/11/19 05:27 PM
09/11/19 05:27 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Dunno about an 02 but I definitely ordered my 01 6 speed 2wd with a 3.54. And my mileage empty at 60 mph is around 23-24 like others...70 MPH 2k rpm, stock tire size, stone stock motor. I'd say the sweet spot on my is around 1700 - 1800 / 60 - 65 mph, any above that and the mileage drops off.
