FP8519PT Compressed Thickness Confusion
#2691912
08/27/19 12:20 PM
08/27/19 12:20 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
The manufacturer lists the compressed thickness as .039" but I found a thread on Moparts that says the compressed thickness of the Fel Pro 8519PT can be anywhere from .041" to .044".
I'm doing a head swap and measured one of my cylinders' pistons as .003" below deck so while I'm at it I have a chance to get the quench distance pretty ideal if I can pick out the right gasket.
This is on a .040" over 440 with 84cc E Street heads. Are there other gaskets that would be a good choice? I read on here that the .039" fel Pro 1009s might not work because of hanging into the bore and the fire ring brinneling the aluminum heads. Thanks!
Re: FP8519PT Compressed Thickness Confusion
[Re: 67Satty]
#2691928
08/27/19 01:05 PM
08/27/19 01:05 PM
Posts: 2,661 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
If the manufacturer says it's .039" they probably know. If they are wrong and it's .002" thicker....I don't think the sky will come falling down.
2011 Drag Pak Challenger
[Re: rickseeman]
#2691986
08/27/19 04:01 PM
08/27/19 04:01 PM
Posts: 277 MN
Willie68coronet
MN
If the manufacturer says it's .039" they probably know. If they are wrong and it's .002" thicker....I don't think the sky will come falling down. I agree. I used those same gaskets on my 440. I was able to get .042 worth of feeler gauges between the head and block with that gasket torqued to spec. Close enough for me.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: rickseeman]
#2692314
08/28/19 02:19 PM
08/28/19 02:19 PM
67Satty
Vista, California
If the manufacturer says it's .039" they probably know. If they are wrong and it's .002" thicker....I don't think the sky will come falling down. No I don't think so either. Just trying to strike a balance between taking advantage of quench with a number in the .040" to .050" range and not worrying about having my heavy 2355 "6 pack" pistons hit my heads. So far I've taken some preliminary measurements and gotten .006" below deck on cylinder 1 and .003" below deck on cylinder 6. So if the Fel Pro 8519s really measure between .041" to .044" compressed it would work out well for what I'm doing.
[Re: 67Satty]
#2692386
08/28/19 07:34 PM
08/28/19 07:34 PM
RapidRobert
I ran into that with some SB felpros, they didn't compress to what was stated & my torque was correct. Maybe they need retorquing after setting overnight or retorqued after breakin, not sure just going by what the felpro man & dave hughes have mentioned in conversations. I have a new 408 & I want dead on 040" quench so I did what Cab mentioned & went with some .040 compressed Cometics & I will be trusting that they will go to what they say they will. EDIT some people have mentioned spraying the individual layers with "high tack" ??? Not sure if needed or not & how that would affect thickness, maybe just KISS & drill out the rivets & call em good.
[Re: Cab_Burge]
#2692464
08/28/19 11:30 PM
08/28/19 11:30 PM
RapidRobert
I will follow that advise, Thanks Cab
