Possible to swap a 2.4 DOHC Turbo into A-body? #2691268
08/25/19 04:14 PM
08/25/19 04:14 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
About 15 or so years ago, I ran across a build thread where someone was building a '73 or '74 Dodge Dart drag car, powered by a Mitsubishi 2.0 liter Turbo four. Unfortunately, I don't remember the forum, and haven't been able to locate it. I've occasionally thought about swapping something like this into my '67 Barracuda. However, I really didn't like the idea of using a non-American engine in my car.
More recently, I got to wondering if it would be possible to use the Chrysler 2.4 liter SRT-4 DOHC Turbo engine instead? Currently, my car has a 225" slant six, with 904 Torqueflite. The main problem I envision would be in trying to adapt/mate the engine to the 904. I know a variation of this engine was used in the Jeep Wrangler, so that might not be a huge issue. But I'm also guessing that running 245 hp thru a 904 is probably not a good idea. So it might be smarter/easier to use a Jeep tranny?
How about rear end? I've done the '72-'75 front disc brake swap, so my car has an 8-1/4". Would that stand up to 245 hp, assuming I didn't abuse it too hard?
Anyway, just tossing the idea around right now. I've done some Googling, but am not turning up anything. Does anyone know if this has been tried or done by anyone? I'd appreciate any thoughts, pro or con. Thanks!
Roger
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Fab64] #2691311
08/25/19 06:17 PM
08/25/19 06:17 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
My thought on the matter is what is your goal with this project ? I think it would be an easier swap with a manual transmission like a T-5 bolted to a Quicktime bell because you will need some RPM's to get that 3000# car rolling with a small displacement engine. The other option is an early A-body 4 speed or an OD box with the 3.09 low gear. Is the plan for a fuel miser or just something different.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: fourgearsavoy] #2691323
08/25/19 06:59 PM
08/25/19 06:59 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Gus beer
I'm interested in several things: better gas mileage, being able to drive it anywhere, better performance, in addition to something different. Do you really think this engine wouldn't easily move my car? A 2004 Dodge SRT4 weighs 2,900 lbs. A Chrysler PT Cruiser with this engine weighed 3,263 - 3,471 lbs. My only reluctance to using a manual transmission is that I'd rather not cut anything.
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Fab64] #2691345
08/25/19 07:52 PM
08/25/19 07:52 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My 2006 Wrangler had the 2.4 with the Mercedes 6-speed and I liked it, but go no better than 20 MPG. I am not sure you can use the transverse mounted 2.4 turbo, but seems that it should work, exhaust might be interesting... shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Fab64] #2691346
08/25/19 07:55 PM
08/25/19 07:55 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Couple of things- I think I know of the dart you speak of, was it gold? If so, that was a nasty machine.
I knew someone who did a "swap" in a wrangler. The 2.4 bolted right up to the standard 6 speed the jeep came with. He had someone cobble together a better exhaust manifold and when it worked, said it was great, but could not get the tune to take advantage of the turbo and still be streetable.
Also keep in mind, if your just going to do a "simple" swap, the pt engine setup and out put are different form the neons.
Good luck, this sounds like a fun project
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: moparjim79] #2691392
08/25/19 10:27 PM
08/25/19 10:27 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Which 4 cylinder motor was Dodge putting in the later model Dakotas? The 4 cylinder Dakota was rear wheel drive. I know the earlier Dakotas used the 2.5 (2.2 family) but Dodge was still installing a 4 cylinder in around 2004, would have had to be something other then the 22 family, right? Gene
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Fab64] #2691395
08/25/19 10:38 PM
08/25/19 10:38 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Why don't you be the person, fabricator, mechanic, that goes and does it, and write the book, take the videos, on how it's done? shruggy
Can do anything you wan't if your equipped with a full machine shop of tools, welders, and knows how to use them.
And all the money, and time to do the project.
They do it all the time on those Motortrend tv channels on cable tv. whistling
Now it can be your turn. twocents
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: hemi71x] #2691399
08/25/19 10:48 PM
08/25/19 10:48 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Sniper] #2691410
08/25/19 11:32 PM
08/25/19 11:32 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
A turbo 318 with 2.45 gears could get 20 mpg and turn an 11 second quarter mile.
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Rhinodart] #2691411
08/25/19 11:36 PM
08/25/19 11:36 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Well, 20 mpg would be nearly double what I'm currently getting, so that would be great. And, I'm not positive, but I'm assuming the Wrangler engine is mounted longitudinally(?). And I believe I read that the normally aspirated 2.4 and the turbo used the same block.
Yes, I think it was either gold or beige. I did more googling and found it: FrankenDart. I'm still looking for the actual build thread, but here's some info on it.
In any case, I'm just starting to look into this, and kick around ideas. Odds are nothing will even come of it. Thanks so far for everyone's input. beer
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Fab64] #2691527
08/26/19 11:46 AM
08/26/19 11:46 AM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
a 999 style 904 would easily handle that 2.4, plus with the low first gearset it would pull out
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Fab64] #2691529
08/26/19 11:48 AM
08/26/19 11:48 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
Quote
245hp through a 904 is not an issue. You're project sounds like an interesting one that I'd love to follow. up
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: burdar] #2691563
08/26/19 12:56 PM
08/26/19 12:56 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
A Slant can easily get 20+, why not fix it? shruggy
I do fully understand the "I want something different" thing.
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: slantzilla] #2691630
08/26/19 04:14 PM
08/26/19 04:14 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
In case anyone's interested, here's a link to pretty much the same swap I just ran across.
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Fab64] #2691650
08/26/19 05:07 PM
08/26/19 05:07 PM
AndyF Offline
AndyF  Offline
Sure it can be done. Shouldn't be all that tough of a swap to do. I could probably do it in my shop with a little help from my friends. One guy I work with has a turbo Subaru engine swapped into his early VW bug. That was a more difficult swap than what you're talking about.
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: AndyF] #2691653
08/26/19 05:15 PM
08/26/19 05:15 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks. One thing I'm concerned about is running a 904 with this computer-controlled motor. On modern cars, so many things are tied together, and controlled by computer - do you envision any issues with a non-computer-controlled transmission?
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Fab64] #2691702
08/26/19 08:34 PM
08/26/19 08:34 PM
AndyF Offline
AndyF  Offline
All depends how you do it. If I was doing the swap I'd get rid of all of the OEM controls on the engine and use an aftermarket EFI computer such as a Holley system. I'm not sure I'd use a 904 trans with that engine though. Seems like you might want something with more speeds and maybe something that can be electronically controlled. Again, it just depends on what you're trying to accomplish. (And how much money you have)
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Fab64] #2691719
08/26/19 09:02 PM
08/26/19 09:02 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
So I followed the link for the Lancer build and I see the link ended without completion. was it another failed project, or was it ever finished and actually driven?
What year computer are you using? Instead of a 904, you could step up to the Liberty trans, or get a computer controlled re42 auto trans (the electric rear drive v6 or light duty v8 trans.) That sould get you up into the early 2000s computer. I also wonder if the newer stick trans computer would work OK without any input from the trans, the older stick trans computers didn't have any input from the trans. Gene
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: Fab64] #2691766
08/26/19 11:44 PM
08/26/19 11:44 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
There used to be member here that had a 2.4 DOHC Turbo Colt with a 904.
He was selling adapter for around $350. but no longer posts here . You might try contacting Dynamic Racing Transmissions I remember they were selling his adapters.
Re: Possible to swap a 2.4 DOHC Turbo into A-body? [Re: AndyF] #2691777
08/27/19 12:40 AM
08/27/19 12:40 AM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks for the ideas. Just exploring options at this point, a lot of this stuff is new to me. I'd also prefer to keep costs down, if possible (dream on!).
Yes, unfortunately, that thread just stops. I found the same guy on another forum, and that thread also stopped. I'm going to join one or both, just to see if I can track down the OP.
No idea on computer yet. Again, more good leads to follow up on.
Thanks. On the Lancer build thread above, there are a couple of links for adapter plates, including this one I believe.
