Page 5 of 7 1 2 3 4 5 6 7
Re: Winter update for the Coronet [Re: Cab_Burge] #2651948
05/04/19 04:59 PM
05/04/19 04:59 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted by Cab_Burge
Why are you using the C and A body BB driver side motor mounts?
Because it is the only bracket that fits.
Re: Winter update for the Coronet [Re: AndyF] #2651957
05/04/19 05:30 PM
05/04/19 05:30 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Seems like you're getting really close to a test drive! Looks great! Keep going! up
Re: Winter update for the Coronet [Re: AndyF] #2691424
08/26/19 01:06 AM
08/26/19 01:06 AM
AndyF Offline OP
AndyF  Offline OP
I haven't worked on the Coronet for a few months but I did get around to mocking up the Corvette power steering pump and the low mount 90 amp alternator. Looks like everything lines up and fits. These two items should move me a little closer to the 21st century.
Re: Winter update for the Coronet [Re: AndyF] #2691483
08/26/19 09:54 AM
08/26/19 09:54 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Andy is that the Land Cruiser alternator? Did you make a pulley or are you using the dual pulley setup?
Gus beer
64 Plymouth Savoy
Dana 60
Re: Winter update for the Coronet [Re: fourgearsavoy] #2691509
08/26/19 10:53 AM
08/26/19 10:53 AM
AndyF Offline OP
AndyF  Offline OP
Yes it is a Denso 210-0177 alternator which was OE on the Land Cruiser for a few years. It came with a dual belt pulley. I machined the front pulley off and kept the inner one. The OE pulley is made from steel and is super heavy.
Re: Winter update for the Coronet [Re: AndyF] #2691519
08/26/19 11:17 AM
08/26/19 11:17 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Is that a one wire hookup?
Re: Winter update for the Coronet [Re: cudadoug] #2691546
08/26/19 12:15 PM
08/26/19 12:15 PM
AndyF Offline OP
AndyF  Offline OP
I usually hook up an external switched 12 volt and a sense wire. It is just two wires to run so most anyone should be able to handle it.
Re: Winter update for the Coronet [Re: AndyF] #2691713
08/26/19 08:56 PM
08/26/19 08:56 PM
USA
hudsonhornet7x Offline
USA
Hello Andy, the alternator and power steering setup look great on your engine. Can you do the same power steering setup with one of your motor plates?
Re: Winter update for the Coronet [Re: hudsonhornet7x] #2691720
08/26/19 09:07 PM
08/26/19 09:07 PM
AndyF Offline OP
AndyF  Offline OP
The Corvette PS housing is flat on the back and it sits forward of the motor plate so it should be fairly easy to mount it to a motor plate. Not very many cars use a motor plate and power steering at the same time so I doubt I'll bother with creating a bracket kit.
Re: Winter update for the Coronet [Re: AndyF] #2691723
08/26/19 09:12 PM
08/26/19 09:12 PM
USA
USA
Thanks for the information. Mine will need both.
Re: Winter update for the Coronet [Re: hudsonhornet7x] #2691724
08/26/19 09:16 PM
08/26/19 09:16 PM
AndyF Offline OP
AndyF  Offline OP
If you are working with a BB or a Hemi then there should be plenty of room. Just buy one of those pumps and a pulley and hang it in space so the belt is straight. You'll probably have about one inch of room behind the pump for the bracket. You'll have to figure how how you want to tension the belt. Any good street rod shop should be able to fabricate a mount for you. If you are working with a G3 then mounts already exist to use this pump.
Re: Winter update for the Coronet [Re: hudsonhornet7x] #2691798
08/27/19 02:09 AM
08/27/19 02:09 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
"Corvette PS pump" is kinda vague , lots of years and models of Vettes out there.
Re: Winter update for the Coronet [Re: AndyF] #2691842
08/27/19 08:15 AM
08/27/19 08:15 AM
USA
USA
Thanks, I was thinking rather the same thing. The setup looks good.
Re: Winter update for the Coronet [Re: pro451bee] #2691897
08/27/19 11:37 AM
08/27/19 11:37 AM
AndyF Offline OP
AndyF  Offline OP
Do a google search on "Type II power steering pumps" and you'll find more info.
Re: Winter update for the Coronet [Re: AndyF] #2692457
08/28/19 11:09 PM
08/28/19 11:09 PM
AndyF Offline OP
AndyF  Offline OP
Here is a picture showing the back side of the PS pump. There is about 1.5 inches of space behind the pump to the front of the block so there is plenty of space to build a bracket that would mount on a motor plate.
Re: Winter update for the Coronet [Re: AndyF] #2692515
08/29/19 08:08 AM
08/29/19 08:08 AM
USA
USA
Yep,
Thanks for the picture. I think that would make for a clean installation.
Re: Winter update for the Coronet [Re: AndyF] #2692586
08/29/19 11:30 AM
08/29/19 11:30 AM
moparx Online content
moparx  Online Content
andy, the 12 point bolts you use, are they ARP's ?
TIA.
beer
Re: Winter update for the Coronet [Re: moparx] #2692623
08/29/19 01:55 PM
08/29/19 01:55 PM
AndyF Offline OP
AndyF  Offline OP
Yes, I use 12 point ARP stainless on all of my builds.
Re: Winter update for the Coronet [Re: AndyF] #2692836
08/30/19 10:21 AM
08/30/19 10:21 AM
thanks andy.
beer
Re: Winter update for the Coronet [Re: AndyF] #2693067
08/31/19 04:38 AM
08/31/19 04:38 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
The ARP Fasteners are the best I have found, And the 12 point fasteners are very appealing to the eye as well as very high quality.
