My old BB pump gas 400 stroker motor (4.300 stroke)had oil pressure similar to yours with 5W20Wt oil hot(above 160 F), no issues ever except when I let the oil level get down to 5 quarts in a stock Mopar 6 quart 1970/1971 Hemi/440 six pack oil pan
It would loose a little oil pressure at the end of a 1/4 mile run when I let off the throttle with the oil level low, never did that with more oil in it above the add line on the oil level dip stick
Full groove main bearings and a lot more oil clearances than yours with no bushings in the lifters with 3 different brands of solid roller lifters in that motor.
I like to use the old rule of 10 lbs. of oil pressure per 1000 RPM, ie 70 lbs. at 7000 RPM
Me thinks your good on using that pressure with hot oil
