valve core for TPM monitor on wheel ?? #2690868
08/24/19 09:53 AM
08/24/19 09:53 AM
moparx Online content OP
moparx  Online Content OP
is there any difference in the valve core used with a tire pressure monitor on a wheel as opposed to a regular valve stem ?
i got a used wheel for my sister's car, and it has the TPM unit on the wheel, but no valve core.
this is my first experience with these sensors.
TIA as always. bow
beer
Re: valve core for TPM monitor on wheel ?? [Re: moparx] #2690911
08/24/19 12:45 PM
08/24/19 12:45 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Im 99% sure same core
But, if in doubt,
pull the TPM sensor and install a typical rubber valve stem
Re: valve core for TPM monitor on wheel ?? [Re: moparx] #2691005
08/24/19 07:22 PM
08/24/19 07:22 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I don't believe that they are the same, but will fit and work. Because of the potential corrosion, I always put a dab of oil on the threads both inside and outside of the stem. That is if the stem is the screw-on style.
Master, again and still
Re: valve core for TPM monitor on wheel ?? [Re: DaveRS23] #2691115
08/25/19 07:33 AM
08/25/19 07:33 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I thought I read that they used a nickel plated core.
Re: valve core for TPM monitor on wheel ?? [Re: mopars4ever] #2691159
08/25/19 10:39 AM
08/25/19 10:39 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I believe it is something like that. The design of the core is the same, but the TPMS cores are of a different material to supposedly reduce corrosion. We have interchanged them for years with just a drop of oil and have never had any problems.
We have seen far more problems with the nut seizing on the stem so that always gets a drop of oil too when we assemble them.
twocents
Re: valve core for TPM monitor on wheel ?? [Re: DaveRS23] #2691170
08/25/19 10:56 AM
08/25/19 10:56 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Anyone know ANY WAY to eliminate these pesky things ? On my 05 they will light up on a slight outside temp change. THEY ARE WAY TOO SENSITIVE.
Re: valve core for TPM monitor on wheel ?? [Re: DaveRS23] #2691172
08/25/19 10:59 AM
08/25/19 10:59 AM
thanks guys ! great to know a standard core will work ! up i'll be sure to oil up the threads as suggested.
stoopid doughnut spare........ rant
beer
Re: valve core for TPM monitor on wheel ?? [Re: moparx] #2691188
08/25/19 11:31 AM
08/25/19 11:31 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
That TPM did save my butt about a month ago ..... a guy across the way pulled apart some pallets and didn’t pick up all the staples. One of them nailed me and that system benefited me then ... but I would have caught it anyways later
Re: valve core for TPM monitor on wheel ?? [Re: dOc !] #2691324
08/25/19 07:07 PM
08/25/19 07:07 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Well.................................Some people take them out of their tires and put them into their spare and just put the spare to 40# or so. Kinda eliminates the spare's usefulness unless you drill holes in the spare so that you can actually mount the monitors.
And then there's this; https://www.1addicts.com/forums/showthread.php?t=207651
