W-200 kick-down linkage
#2691107
08/25/19 06:22 AM
08/25/19 06:22 AM
Posts: 401 Norway
General 68
Norway
Hello Just got a '77 W-200 truck for cheap. It is missing the upper part of the kick-down linkage. The bellcrank on the intake is there. The Edelbrock carb needs a part on the throttle lever to attach the missing linkage to. Can you see exactly what is missing? A photo of the evaquation would help a lot😀 Attached is a picture showing the situation as it is now. Thanks
Re: W-200 kick-down linkage
[Re: General 68]
#2691116
08/25/19 07:34 AM
08/25/19 07:34 AM
RWG75
RWG75
Here's a generic picture of the 3 piece kick down showing the bit your missing. They do repop the entire setup for some crazy amount of money but dunno about buying individual pieces. If yer asking about the missing bit for the carb, can't help ya with that because thermoquad. Once upon a time edlebrock did offer a throttle stud adapter piece for mopars but as I recall it was crap.
[Re: Uberpube]
#2691199
08/25/19 11:54 AM
08/25/19 11:54 AM
Posts: 19,521 north of coder
moparx
please use the buchillion setup instead. you will be happier with it. my opinion on the lokar is not good. i have changed over a dozen lokar setups back to the factory or the buchillion. lokar is just a "fitzall, hope it works" GM adaptation that uses cheap, bicycle type cable and somewhat flimsy brackets. as the cable stretches, you will be constantly fiddling with your adjustment. just my experience and opinion. your mileage may vary [but i'm not the only one with this opinion]
[Re: ]
#2691225
08/25/19 01:22 PM
08/25/19 01:22 PM
Posts: 16,156 Mesa, Arizona
dart4forte
Mesa, Arizona
xLURKxDOGx over at FABO has what you are looking for. Looks like you have the single kick down rod, you just need the bracket assembly. You’ll also need the Holley linkage adapter which you can get from Summitt. The kick down stud is fairly easy to find.
Abe Lincoln
[Re: Uberpube]
#2691230
08/25/19 01:49 PM
08/25/19 01:49 PM
dart4forte
Mesa, Arizona
Thanks for the heads up on that, hopefully they have something I can adapt to the proflo xt efi intake setup. Might have to do some creative fabbing
Abe Lincoln
[Re: General 68]
#2691261
08/25/19 03:54 PM
08/25/19 03:54 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The Edelbrock lever extension is #1481 and the pic below shows the linkage installation. You'll need the stud, top link and spring.
[Re: John_Kunkel]
#2691267
08/25/19 04:12 PM
08/25/19 04:12 PM
Posts: 401 Norway
General 68
Norway
Thanks! I understand that I need the throttle rod, the spring and the bracket with the small link that connects the rod? AND the throttle lever piece!?
[Re: General 68]
#2691525
08/26/19 11:32 AM
08/26/19 11:32 AM
moparx
i didn't get a chance to look yesterday. sorry ! i'll do that this afternoon after i get back from the doc's office. i'll post either way with what i find in my "stuff"
