Re: moparan619's Turbo Gen 3 Valiant
[Re: mopar_man619]
#2690023
08/21/19 02:01 PM
08/21/19 02:01 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
that 6.1 has a hole in it? are you going to keep the block ? I know some one who would be interested in it if you are going to junk it.
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: 65Dodge440]
#2690650
08/23/19 02:26 PM
08/23/19 02:26 PM
Posts: 2,256 IL
furious70
IL
did you redrill the heads for the manifold bolt pattern like that 4 door coronet did or need to do that yet or find a different option?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: 65Dodge440]
#2690782
08/23/19 10:01 PM
08/23/19 10:01 PM
Posts: 340 San Diego, CA
mopar_man619
San Diego, CA
I gotcha lol Oh man you're leaving us hanging..... any new photos of the progress?
1967 Plymouth Valiant Gen III Hemi 11.42@119 youtube.com/moparman619
[Re: furious70]
#2690783
08/23/19 10:02 PM
08/23/19 10:02 PM
mopar_man619
San Diego, CA
yup drill and tap did you redrill the heads for the manifold bolt pattern like that 4 door coronet did or need to do that yet or find a different option?
[Re: mopar_man619]
#2690897
08/24/19 11:41 AM
08/24/19 11:41 AM
Posts: 2,256 IL
furious70
IL
What are planning for the car mount alternator they usually interferes with the frame?
[Re: furious70]
#2691064
08/24/19 10:48 PM
08/24/19 10:48 PM
mopar_man619
San Diego, CA
truck cover. pics soon What are planning for the car mount alternator they usually interferes with the frame?
[Re: mopar_man619]
#2691071
08/24/19 11:12 PM
08/24/19 11:12 PM
Posts: 2,256 IL
furious70
IL
truck cover. pics soon What are planning for the car mount alternator they usually interferes with the frame? I'll be interested to see that, I thought the truck cover interfered with the front mount TB.
[Re: furious70]
#2691265
08/25/19 04:10 PM
08/25/19 04:10 PM
mopar_man619
San Diego, CA
it does. but where theres a will theres a way truck cover. pics soon What are planning for the car mount alternator they usually interferes with the frame? I'll be interested to see that, I thought the truck cover interfered with the front mount TB.
[Re: mopar_man619]
#2704400
10/06/19 06:59 PM
10/06/19 06:59 PM
mopar_man619
San Diego, CA
found a truck front cover on craigslist and a rad at MATS swap meet
[Re: 65Dodge440]
#2704772
10/08/19 07:06 AM
10/08/19 07:06 AM
Ray408G3Hemi
Springtown Pa
Are you putting oil lines in that pan for the turbos? Interested to see how you do it, because I might be doing the same thing at some point. Great build and thanks for posting your progress. X2
[Re: 65Dodge440]
#2706320
10/13/19 03:19 AM
10/13/19 03:19 AM
mopar_man619
San Diego, CA
I used the dipstick hole on the pan for my return. its 10an I believe and used a truck dipstick on the drivers side of the engine. Are you putting oil lines in that pan for the turbos? Interested to see how you do it, because I might be doing the same thing at some point. Great build and thanks for posting your progress.
[Re: mopar_man619]
#2706340
10/13/19 08:50 AM
10/13/19 08:50 AM
Ray408G3Hemi
Springtown Pa
I used the dipstick hole on the pan for my return. its 10an I believe and used a truck dipstick on the drivers side of the engine. Are you putting oil lines in that pan for the turbos? Interested to see how you do it, because I might be doing the same thing at some point. Great build and thanks for posting your progress. Good thinking
[Re: mopar_man619]
#2706432
10/13/19 03:44 PM
10/13/19 03:44 PM
mopar_man619
San Diego, CA
turbo's here ! on3 performance 7875. t4 flange. 3 inch downpipe
[Re: mopar_man619]
#2706433
10/13/19 03:48 PM
10/13/19 03:48 PM
mopar_man619
San Diego, CA
playing with some bends on the hot side. with a truck front cover and a car intake the alternator location needs to be manipulated. also look where I shaved/ground down the front cover under the throttle body to use a car intake.
[Re: mopar_man619]
#2706436
10/13/19 04:13 PM
10/13/19 04:13 PM
mopar_man619
San Diego, CA
next I was in the market for a cable driven throttle body. bbk were kinda pricey and efisource was just releasing adapters to use a ls throttle body. I know I know. heres link for adapter https://www.efisource.com/wp/shop/gen-3-hemi-throttle-body-adapter/and the throttle body is from warr performance. tb is 92mm and I believe the intake open is only 90mm or so. needs to be bored
