Re: Edelbrock Heads Now Cheaper Than Stealths
[Re: 67Satty]
#2690297
08/22/19 10:51 AM
08/22/19 10:51 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Life is good for the bb mopar guys! 440 source will still have its niche with the stock look.
2 kids and a dog
[Re: 67Satty]
#2690312
08/22/19 11:45 AM
08/22/19 11:45 AM
Posts: 17,860 S.E. Michigan
ZIPPY
S.E. Michigan
Not bad at all If I remember correctly I paid 1050 for my RPM heads, but that was a long time ago and I held out for the 10% discount. The almost* stock appearance of the Stealth head will give it continued success. *Lack of a heat crossover is obvious from the top
Rich H.
Esse Quam Videri
[Re: 67Satty]
#2690442
08/22/19 07:42 PM
08/22/19 07:42 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
The price of the 84cc Edelbrock E Street heads has been reduced to $1112.85. With Summit's $100 off deal if you spend more than $1000 and free shipping this brings the price down to $1012.85, cheaper than a pair of $1000 440 Source heads since 440 Source doesn't offer free shipping. How about the 75 cc head?
[Re: BSB67]
#2690452
08/22/19 08:11 PM
08/22/19 08:11 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
The price of the 84cc Edelbrock E Street heads has been reduced to $1112.85. With Summit's $100 off deal if you spend more than $1000 and free shipping this brings the price down to $1012.85, cheaper than a pair of $1000 440 Source heads since 440 Source doesn't offer free shipping. How about the 75 cc head? Not bad https://www.summitracing.com/parts/edl-5090
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: 67Satty]
#2690480
08/22/19 09:45 PM
08/22/19 09:45 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Are the E street heads better than the Trick Flow 240 heads?
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: Digger73]
#2690489
08/22/19 10:46 PM
08/22/19 10:46 PM
BSB67
Prospect, PA
Digger73 (Mike) How do you measure better? Power potential goes to TF 240.
[Re: BSB67]
#2690492
08/22/19 10:48 PM
08/22/19 10:48 PM
Digger73
Portland, Oregon
Just asking because they are the same price.
Digger73 (Mike)
[Re: Digger73]
#2690495
08/22/19 10:54 PM
08/22/19 10:54 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Digger73 (Mike) Thats a pair for the Edelbrocks,,,each for the TF240
[Re: Digger73]
#2690514
08/23/19 12:30 AM
08/23/19 12:30 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Digger73 (Mike) The tfs 240 head price is per head.
[Re: MFR440]
#2705560
10/10/19 02:51 PM
10/10/19 02:51 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
“Better” than EZ’s??
Totally depends on what you’re trying to do with them.
I would say it like this......
The RPM heads that have gone through my shop needed less work to be “right” than the EZ heads. And I’ve had many of both through the shop.
But I don’t really consider those direct competitors with each other.
[Re: MFR440]
#2705570
10/10/19 03:16 PM
10/10/19 03:16 PM
Posts: 2,094 central texas
krautrock
central texas
Sorry for dragging up an older thread, but Mancini has deal going on the RPM heads for about $1350 a pair. Are they much better than the EZ‘s? I am in the planning stages of a pump gas 440 build and wondering if I should go ahead and pick these up or wait until I know better what will be going into my build. i think those edelbrock heads are the Mopar Performance RPM heads with straight plugs. just an FYI.
[Re: fast68plymouth]
#2705696
10/10/19 09:15 PM
10/10/19 09:15 PM
Posts: 986 Indiana
MFR440
Indiana
But I don’t really consider those direct competitors with each other. Thanks for the reply - you are a guru for sure!👍 But what if I don’t know what I’m tying to do with them? 😄 My options are pretty wide open. I have a 440 block with a forged crank, stock rods, and some decent pistons...but I am also considering a 440-Source stroker kit. Are the RPM’s overkill for a mild build? It just seemed like a really good deal, and I am wondering if I might be able to “grow” into them later. 😉
