Re: Mechanical six pack budget build.
[Re: Milan454]
#2690128
08/21/19 08:51 PM
08/21/19 08:51 PM
Posts: 4,210 New York
polyspheric
New York
I don't have the data, but compare your 2300 PVCR to the factory size. If same or slightly smaller I'd just try it out. If significantly smaller your WOT mixture may be lean enough to cause problems. Will you use an aftermarket plate with jets to replace the PVCR? The PV vacuum rating must be low enough that you can't reach it at any cruising speed, but will kick in whenever you need passing or acceleration, regardless of the number. This means that the PV will vary based on axle ratio and car weight, your driving style, etc.
Boffin Emeritus
[Re: polyspheric]
#2690198
08/21/19 11:57 PM
08/21/19 11:57 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
3 500 cfm carbs. Car went 6.27 @ 110 in 3700 lb car
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2690750
08/23/19 09:08 PM
08/23/19 09:08 PM
Posts: 19 Garagemahal
Milan454
Garagemahal
3 500 cfm carbs. Car went 6.27 @ 110 in 3700 lb car Nice! But did you read the post?
[Re: Milan454]
#2690791
08/23/19 10:27 PM
08/23/19 10:27 PM
sixpackgut
Charleston
3 500 cfm carbs. Car went 6.27 @ 110 in 3700 lb car Nice! But did you read the post? Yes. I have to disagree with your choice of using smaller carbs but on a mild 440 it will probably work fine. As for jetting tips. I jet as necessary. Someone will disagree with me and want to start arguing with me and I really don't want to deal with it. But for starters, i would probably just throw 72 jets in the outboards and than jet as necessary. When I was running sixpacks, i may spend 5 hours laying black marks and making my neighbors crazy on a saturday.
