Need help on a few under car issues #2690026
08/21/19 02:12 PM
08/21/19 02:12 PM
New Jersey
Choppintime Offline OP
New Jersey
Added a set of frame connectors to my Challenger. Wondering where I'll need to drill through one of them for emergency brake cable. Also, switched it over to a four speed and welded in a hump. Where do I need to weld the bracket for clutch/z bar stuff ?
If someone has pictures it would be appreciated. Need to get both of these things done before I paint the underside.
Thanks, !
Re: Need help on a few under car issues [Re: Choppintime] #2690029
08/21/19 02:22 PM
08/21/19 02:22 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Slotting the frame connectors for the cable may be needed depending on what type of connectors you use. The sawblade style ones that weld to the floor the whole way and you have to do it.
Re: Need help on a few under car issues [Re: Neil] #2690032
08/21/19 02:29 PM
08/21/19 02:29 PM
New Jersey
New Jersey
I used the US car tool connectors and yes, welded them to the floor. I'm just wondering what area/distance I need to drill the hole. I'm assuming staggering the holes so cable isn't kinked. Like to see a picture if anyone has done it.
Re: Need help on a few under car issues [Re: Choppintime] #2690214
08/22/19 02:28 AM
08/22/19 02:28 AM
None
71rm23 Offline
71rm23  Offline
None
Youll have to trial fit your cables where they will lay at
Re: Need help on a few under car issues [Re: Choppintime] #2691169
08/25/19 10:56 AM
08/25/19 10:56 AM
georgia
moparpro Offline
moparpro  Offline
georgia
what size cotter pins for b body suspension parts thanks
