69 Super Bee e-coated #268972
03/27/09 11:10 PM
03/27/09 11:10 PM
New Castle, In. 47362
dbdcuda Offline OP
dbdcuda  Offline OP
We just had this 69 Hemi Bee e coated yesterday, thought I would share some pics.
Before
dornautocraft.com
Re: 69 Super Bee e-coated [Re: dbdcuda] #268973
03/27/09 11:12 PM
03/27/09 11:12 PM
dbdcuda Offline OP
dbdcuda  Offline OP
After
dornautocraft.com
Re: 69 Super Bee e-coated [Re: dbdcuda] #268974
03/27/09 11:17 PM
03/27/09 11:17 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Where did you have it done?
Re: 69 Super Bee e-coated [Re: dbdcuda] #268975
03/28/09 03:54 AM
03/28/09 03:54 AM
Rhode Island
GoodfellaHenry70 Offline
Rhode Island
what's an E-coat?
"No big deal...It's called Advanced Dilusionary schizophrenia with involuntary narcissistic rage." Just call me Hank.
Re: 69 Super Bee e-coated [Re: GoodfellaHenry70] #268976
03/28/09 10:17 AM
03/28/09 10:17 AM
SE Pa.
LimeliteAero Offline
SE Pa.
what's an E-coat?
what he said!
Re: 69 Super Bee e-coated [Re: GoodfellaHenry70] #268977
03/28/09 10:18 AM
03/28/09 10:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what's an E-coat?
It's electrically applied primer , the entire car is dipped in a vat of the paint, does the entire car , it's not cheap ...
Re: 69 Super Bee e-coated [Re: JohnRR] #268978
03/28/09 10:45 AM
03/28/09 10:45 AM
MO
cdp Offline
cdp  Offline
MO
Where did you have it done? In the Indy area?
Give us some more facts. Cost, location, etc.. I'd like to do this to my GTX.
Re: 69 Super Bee e-coated [Re: cdp] #268979
03/29/09 10:01 PM
03/29/09 10:01 PM
Indiana USA
DBishop68 Offline
DBishop68  Offline
Indiana USA
Re: 69 Super Bee e-coated [Re: DBishop68] #268980
03/29/09 10:34 PM
03/29/09 10:34 PM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
Can we get some specifics on the hemi bee? That has to be in my top 3 all time favorite cars.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: 69 Super Bee e-coated [Re: gtsuperbee] #268981
03/30/09 01:06 AM
03/30/09 01:06 AM
Oh
His and Her 69's Offline
Oh
I hope you have better luck with your e-coating then me.
My doors are swelling out at the seam on the bottom because all the stripper was not neutralized correctly.
I was told that it was from electrolisis forming in there from the stripper growing in the seams.
These were a set of rust free doors that I had done.
I also had some spots on my fenders that was not covered with the e-coat because there was air bubbles trapped in the top corners. The fenders are doing fine after the process though and I just sprayed some undercoating in the bare spots.
David
Re: 69 Super Bee e-coated [Re: gtsuperbee] #268982
03/30/09 01:10 PM
03/30/09 01:10 PM
dbdcuda Offline OP
dbdcuda  Offline OP
It's a white on white numbers matching Hemi, 4 spd, buckets, console, black stripe, air grabber, quarter scoops, 9600 miles, ex drag car. It's gonna be sharp.
dornautocraft.com
Re: 69 Super Bee e-coated [Re: dbdcuda] #268983
03/30/09 10:12 PM
03/30/09 10:12 PM
gtsuperbee Offline
gtsuperbee  Offline
Do you have any before pics you can post for me. I'd really appreciate it if you could. If so, thanks for responding and going out of your way for a cerified super bee nut
Re: 69 Super Bee e-coated [Re: gtsuperbee] #268984
03/31/09 12:48 PM
03/31/09 12:48 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Here it is at Dragway 42 in Ohio in the late 70's!
We need to get better pictures of the pictures from the owner.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: 69 Super Bee e-coated [Re: BradD] #268985
03/31/09 12:50 PM
03/31/09 12:50 PM
BradD Offline
BradD  Offline
The Motor!
Re: 69 Super Bee e-coated [Re: BradD] #268986
03/31/09 01:09 PM
03/31/09 01:09 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
Does that car belong to Ron in MI? Lives about a 3 miles from me, but it's been away awhile.
KID
Re: 69 Super Bee e-coated [Re: Kidsixpack] #268987
04/01/09 09:48 AM
04/01/09 09:48 AM
BradD Offline
BradD  Offline
The EDP or E-coat process is done through Dorn Autocraft in New Castle, IN. You can email us at info@dornautocraft.com
Thanks, Brad
And Kid, yes it is Ron's!
Re: 69 Super Bee e-coated [Re: BradD] #268988
04/01/09 09:52 AM
04/01/09 09:52 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Do you have to scuff the e-coat prior to priming or is there a certaing primer that will stick to it?
Re: 69 Super Bee e-coated [Re: Dave Watt] #268989
04/01/09 10:01 AM
04/01/09 10:01 AM
BradD Offline
BradD  Offline
PPG claims you can paint over this without scuffing. It was baked for 45 minutes at 390-410 degrees. We always scuff!
How's it going Dave?
Re: 69 Super Bee e-coated [Re: BradD] #268990
04/01/09 10:57 AM
04/01/09 10:57 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Different opinions on what to do with the e-coating, just like when buying a reproduction panel. Scuff it with Scotch Brite, scuff it with sandpaper, remove it on the outside, etc.
I assume you would scuff a little rougher if you were to apply a skim coat of filler for blocking.
Going good here, busy though.
Re: 69 Super Bee e-coated [Re: Dave Watt] #268991
04/01/09 12:49 PM
04/01/09 12:49 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I left a satellite of mine outside with the e-coated quarters... I epoxied the seams where I welded and a few spots. Well where the ecoat was, its all surface rust now, where the epoxy went over it, looks just like when sprayed.
I can't see spending what it probally cost to get it done... I'd rather did a car in epoxy to get it into the frame and such then spray the rest.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
