69 Super Bee e-coated
#268972
03/27/09 11:10 PM
03/27/09 11:10 PM
Posts: 164 New Castle, In. 47362
dbdcuda
We just had this 69 Hemi Bee e coated yesterday, thought I would share some pics. Before
dornautocraft.com
Re: 69 Super Bee e-coated
[Re: dbdcuda]
#268974
03/27/09 11:17 PM
03/27/09 11:17 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Where did you have it done?
[Re: GoodfellaHenry70]
#268977
03/28/09 10:18 AM
03/28/09 10:18 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
what's an E-coat?
It's electrically applied primer , the entire car is dipped in a vat of the paint, does the entire car , it's not cheap ...
[Re: DBishop68]
#268980
03/29/09 10:34 PM
03/29/09 10:34 PM
Posts: 2,230 restos just aren't my thing
gtsuperbee
Can we get some specifics on the hemi bee? That has to be in my top 3 all time favorite cars.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
[Re: gtsuperbee]
#268982
03/30/09 01:10 PM
03/30/09 01:10 PM
dbdcuda
It's a white on white numbers matching Hemi, 4 spd, buckets, console, black stripe, air grabber, quarter scoops, 9600 miles, ex drag car. It's gonna be sharp.
dornautocraft.com
[Re: gtsuperbee]
#268984
03/31/09 12:48 PM
03/31/09 12:48 PM
Posts: 543 Indiana, Just Off I-70
BradD
Here it is at Dragway 42 in Ohio in the late 70's! We need to get better pictures of the pictures from the owner. Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: Kidsixpack]
#268987
04/01/09 09:48 AM
04/01/09 09:48 AM
BradD
The EDP or E-coat process is done through Dorn Autocraft in New Castle, IN. You can email us at info@dornautocraft.comThanks, Brad And Kid, yes it is Ron's!
[Re: Dave Watt]
#268989
04/01/09 10:01 AM
04/01/09 10:01 AM
BradD
PPG claims you can paint over this without scuffing. It was baked for 45 minutes at 390-410 degrees. We always scuff! How's it going Dave?
[Re: Dave Watt]
#268991
04/01/09 12:49 PM
04/01/09 12:49 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I left a satellite of mine outside with the e-coated quarters... I epoxied the seams where I welded and a few spots. Well where the ecoat was, its all surface rust now, where the epoxy went over it, looks just like when sprayed.
I can't see spending what it probally cost to get it done... I'd rather did a car in epoxy to get it into the frame and such then spray the rest.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#268992
04/01/09 03:16 PM
04/01/09 03:16 PM
BradD
It may also depend on the coater! The place I use is the only place in North America that the Military will use because of their strict guidelines on the treating/cleaning processes. The Ecoat is PPG epoxy! I have seen panels ecoated by other companys that looked terrible! I personally wouldn't leave a primered car or part outside in the weather. We were told years ago by the PPG reps that epoxy IS porous and UV rays will break it down. It should be top coated if it is to be subjected to the elements of nature! Also any time you have two pieces of metal sandwiched together you are not going to get fluid between those panels unless there is a slight gap or seperation for air and fluid to flow. There will always be some form of rust between pinchwelds and laps unless they are unfolded or cut apart and cleaned or there is enough gap for fluid and air to flow! A gray scotchbrite or equivelant is all that is needed to lightly scuff the surface for the topcoat or filler/glaze to "bite". Brad
