Re: 3500 Dodge Ram Woes
[Re: Sammy]
#2689526
08/19/19 08:05 PM
08/19/19 08:05 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Are you sure your def tank level isn’t to low?
Do you have a code reader that will clear code?
Do you know what relay(s) you need to jumper to get you 150 more miles (on one key cycle)?
Hit up a Cummins forum, it’s a modern diesel you need to be prepared!
Red
[Re: BIGGERED]
#2689563
08/19/19 09:48 PM
08/19/19 09:48 PM
Posts: 151 Hastings MN
moparfrank
Hastings MN
I have a 15 Ram 3500 that did that when it got below -15. It left me stranded in Iowa once and in Wisconsin twice both times on a weekend. I cured it with a EFILive tuner and programming. No problems since and I have over 130K on the clock. It had been to the dealer at least six times to be fixed.
[Re: BIGGERED]
#2689655
08/20/19 08:56 AM
08/20/19 08:56 AM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Red
I always keep it at 100% full. It cleared the code once then 35 miles later, no engine light but said it was going to to 5mph after the next 150 miles. I was 450+ miles away from home yesterday.
[Re: moparfrank]
#2689657
08/20/19 08:58 AM
08/20/19 08:58 AM
Sammy
Wind Gap,Pa.
I have a 15 Ram 3500 that did that when it got below -15. It left me stranded in Iowa once and in Wisconsin twice both times on a weekend. I cured it with a EFILive tuner and programming. No problems since and I have over 130K on the clock. It had been to the dealer at least six times to be fixed. It was 91 degrees yesterday and the truck has 7800 miles on it. 3rd time adding DEF Fluid. Container of DEF was new and never opened. This sure does not give me a warm a fuzzy feeling to drive long distances on the weekends now.
[Re: BIGGERED]
#2689706
08/20/19 11:44 AM
08/20/19 11:44 AM
Sammy
Wind Gap,Pa.
Granted my truck is a 1500 Eco Diesel but there is a way to jumper a relay to get you out of limp mode if you reach the end of the count down
Red I'd like to know how to do it. I was told you can only do it once with a hand held code remover.
[Re: Sammy]
#2689726
08/20/19 01:04 PM
08/20/19 01:04 PM
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Red
I always keep it at 100% full. It cleared the code once then 35 miles later, no engine light but said it was going to to 5mph after the next 150 miles. I was 450+ miles away from home yesterday. I was digging on the Cummins forums and there was mention of letting your def tank level drop a bit as when you continually top it off the system thinks you are not using any DEF. Something to consider! Red
[Re: BIGGERED]
#2689749
08/20/19 02:32 PM
08/20/19 02:32 PM
Sammy
Wind Gap,Pa.
Red
I always keep it at 100% full. It cleared the code once then 35 miles later, no engine light but said it was going to to 5mph after the next 150 miles. I was 450+ miles away from home yesterday. I was digging on the Cummins forums and there was mention of letting your def tank level drop a bit as when you continually top it off the system thinks you are not using any DEF. Something to consider! Red Diesel tech says there is a shelf life once added to your DEF tank. If you're not driving it a lot and putting a load on the engine, theres a great possibility that the DEF fluid is getting old and contaminating the system causing error codes. Just throwing this out there which does make sense. Truck isn't driven much at all.
[Re: Sammy]
#2689956
08/21/19 10:16 AM
08/21/19 10:16 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
It's a shame that deleting that crap on the newer trucks voids the warranty. It ought to extend it, lol.
[Re: an8sec70cuda]
#2690013
08/21/19 01:17 PM
08/21/19 01:17 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Like someone mentioned I would let the DEF tank get low so you can reduce the average age of what is in the def tank. We have had a few DEF pickup trucks here at my work and the DEF systems have given very little trouble. Each truck has had a DEF tank and heater replaced once in its life but beyond that no other problems. When we quit driving our ford truck every day it eventually came up with a contaminated DEF code that would come back as soon as you cleared it. It had a 1/2 tank of DEF so I topped it off with fresh and the problem hasn't come back. The 2016 chevy I use as my personal truck uses so little DEF with my driving that I worry about it getting old so when it says it is low(no gauge) I only put 2.5 gallons in it instead of the 5 it holds.
68 Barracuda Formula S 340
[Re: Sammy]
#2690135
08/21/19 09:13 PM
08/21/19 09:13 PM
Posts: 948 Central Michigan
nuthinbutmopar
Central Michigan
Keeping it full is your problem. I bought a new aerial fire truck at work (over $1M), and it was the first the department had with DEF. They "topped it off" 2-3 times a WEEK, so the level sensor never moved. Threw a code for a defective sensor and the entire tank had to be replaced under warranty. 6 weeks later, same thing. That's when we found the root cause. It's one of the many safeties required by the government to make sure you don't mess with the system. let it go down to AT LEAST 1/2 is what Cummins told us...
[Re: kenworth_goose]
#2690822
08/24/19 12:04 AM
08/24/19 12:04 AM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
my new 2500 has just under 9k on it and I've put about 4 gallon in it so far and it's down to a 1/4 tank of def now and I just purchased 2 new jugs of fluid today. I haven't had any issues. I do let mine run down usually to around 1/2 before I top it off. I have read someplace that it's mostly water. If you ever get stuck somewhere and run low, distilled water will get you on your way. I won't own a diesel anything built after Oct 2003, and my preference is pre 1998. 1998 is when the low NOx software started and EGR started Oct 2003. Kevin
[Re: nuthinbutmopar]
#2690840
08/24/19 08:10 AM
08/24/19 08:10 AM
Sammy
Wind Gap,Pa.
Keeping it full is your problem. I bought a new aerial fire truck at work (over $1M), and it was the first the department had with DEF. They "topped it off" 2-3 times a WEEK, so the level sensor never moved. Threw a code for a defective sensor and the entire tank had to be replaced under warranty. 6 weeks later, same thing. That's when we found the root cause. It's one of the many safeties required by the government to make sure you don't mess with the system. let it go down to AT LEAST 1/2 is what Cummins told us... The last time I filled it right up to the top was when it was just above 1/4 tank. I was towing when it went down. Now 800 miles later driving with no trailer, the gauge hadn't moved. I've been driving it every day since to get that gauge to come down some.
#2691038
08/24/19 08:58 PM
08/24/19 08:58 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I have read someplace that it's mostly water. I thought it was mostly piss.
[Re: Kern Dog]
#2691044
08/24/19 09:12 PM
08/24/19 09:12 PM
Twostick
Still wishing...
Still wishing...
I have read someplace that it's mostly water. I thought it was mostly piss. Urea diluted with distilled water apparently which is why distilled water won't hurt it, at least in above freezing. Tap water will cause problems because of the various chemicals and minerals in it. Kevin
[Re: Kern Dog]
#2691045
08/24/19 09:18 PM
08/24/19 09:18 PM
Posts: 1,824 South Bend
John Brown
South Bend
I have read someplace that it's mostly water. I thought it was mostly piss. That's what Urea is. Dried up piss. Sure gets expensive when you gotta buy it by the gallon.
