904 Vent relocation and CSR shield #2689379
08/19/19 01:18 PM
08/19/19 01:18 PM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
I am wanting to re locate my transmission vent on my 904. The recommended locations I have seen would interfere with the CSR transmission shield that I run. I don't want to modify the shield at all in fear that it might not get re certified that way Is there any issue with locating the vent in the tail housing?
68 Barracuda Formula S 340
Re: 904 Vent relocation and CSR shield [Re: Bad340fish] #2689418
08/19/19 02:38 PM
08/19/19 02:38 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I run a CSR shield with a trans brake my transmission gut left the vent in the front of the trans have had no problems with it leaking
Re: 904 Vent relocation and CSR shield [Re: scottb] #2689426
08/19/19 03:11 PM
08/19/19 03:11 PM
Tulsa OK
Tulsa OK
That is good to hear. However since this is street driven I wouldn't mind the vent being back farther from the hottest part of the exhaust. I had an overfill or over overheat situation last year where it barfed fluid it out of the vent and it caught fire on the headers on the side of the highway. Luckily there was zero damage and after it did that it never did it again.
Re: 904 Vent relocation and CSR shield [Re: Bad340fish] #2689470
08/19/19 04:56 PM
08/19/19 04:56 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
You could put the vent in the tail housing but keep it away from the parking gear. It could throw oil out the vent. I put in a short barbed fitting and ran a hose to a vented catch can.
Re: 904 Vent relocation and CSR shield [Re: rickraw] #2689525
08/19/19 07:56 PM
08/19/19 07:56 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I run my CSR shield with the case vent..... I’ll see if I can conjure up a pict. I use a quick connect air hose fitting and run the line to a catch can
Re: 904 Vent relocation and CSR shield [Re: J_BODY] #2690015
08/21/19 01:27 PM
08/21/19 01:27 PM
Tulsa OK
Tulsa OK
Good point, thanks!
That would be great Jay, thanks!
I do like the idea of a catch can. If my car ever 100% didn't leak trans fluid I would worry about it. My 727 leaked just enough I topped it off before drag week each year lol.
Re: 904 Vent relocation and CSR shield [Re: Bad340fish] #2690139
08/21/19 09:20 PM
08/21/19 09:20 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Well the floor is in the car and I’m currently running my old blanket since slow bracket Betty is between the fenderwells. But here’s a pict of the trans and the location of the vent. The plastic breather is gone and a 90 degree airline quick connect is in its place.
Re: 904 Vent relocation and CSR shield [Re: J_BODY] #2690140
08/21/19 09:22 PM
08/21/19 09:22 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: 904 Vent relocation and CSR shield [Re: J_BODY] #2690546
08/23/19 08:25 AM
08/23/19 08:25 AM
NC
440Jim Offline
440Jim  Offline
NC
All my 727 builds have the vent like J-Body shows.
Re: 904 Vent relocation and CSR shield [Re: Bad340fish] #2690547
08/23/19 08:28 AM
08/23/19 08:28 AM
NC
440Jim Offline
440Jim  Offline
NC
The cast dividers in different cases can vary. So look if a little grinding is needed on yours to ensure any liquid drains down.
Re: 904 Vent relocation and CSR shield [Re: 440Jim] #2690567
08/23/19 09:32 AM
08/23/19 09:32 AM
Tulsa OK
Tulsa OK
Thank you for the replies and the pictures. I could swear my shield covers the case 100% with no room for a vent but I will check it out again before I do something.
Re: 904 Vent relocation and CSR shield [Re: Bad340fish] #2690600
08/23/19 11:23 AM
08/23/19 11:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I did mine the same way that Jim shows(I used his pic for directions)
EDIT
this is for a 727.. I dont know if they are the same
wave
