shaker base plate stud markings? #2688750
08/17/19 02:00 PM
08/17/19 02:00 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Trying to determine if a shaker base plate is original or not. I think one way is to look at the markings on the head of the studs? anyone have information about this?
Thank you
Re: shaker base plate stud markings? [Re: sbcjd] #2688857
08/17/19 07:11 PM
08/17/19 07:11 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Original run 70 bases had this stud head with markings shown on left, 5 over SB.
Sometime later, during the 71 run they went to the smaller head with no markings longer stud, shown on right.
A lot of over the counter or NOS bases had the later stud.
There are a lot of subtle differences other than the studs in a reproduction base verses original..
Re: shaker base plate stud markings? [Re: sbcjd] #2688868
08/17/19 07:44 PM
08/17/19 07:44 PM
Iowa
71 SHAKR Offline
71 SHAKR  Offline
Iowa
Easiest way is by studs as in the pic Mccannix just posted. Also I believe the metal on original bases can be wavy from the way the vender press cut the bases. The repos are straight and not wavy as they are cut differently. Mccannix...please correct me if I'm wrong!
Re: shaker base plate stud markings? [Re: mccannix] #2688933
08/17/19 11:43 PM
08/17/19 11:43 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Thank you, the picture really helps.
Re: shaker base plate stud markings? [Re: sbcjd] #2688970
08/18/19 07:41 AM
08/18/19 07:41 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
These studs were used in many applications. Where can you get them? I need some to repair the header panel on a 69 Charger. They are always broken off.
Re: shaker base plate stud markings? [Re: fastmark] #2689021
08/18/19 10:35 AM
08/18/19 10:35 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Chrysler used the numbered stud on lots of applications on various models for many years....
To name a few...E body trunk plates, top rad support, window guide part ..top picture.
Earliest I have seen them is on these lower window stops on a 67 Belvedere..bottom picture
The trick is removing them.
Re: shaker base plate stud markings? [Re: mccannix] #2689075
08/18/19 01:14 PM
08/18/19 01:14 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Any other tips in distinguishing a original base plate from a reproduction besides the studs?
Re: shaker base plate stud markings? [Re: mccannix] #2689091
08/18/19 02:11 PM
08/18/19 02:11 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
So the ones you have in the picture that are off are ones you removed and not ones you have purchased, correct?
Re: shaker base plate stud markings? [Re: fastmark] #2689205
08/18/19 09:19 PM
08/18/19 09:19 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
The ones I posted pictures of are from some of the inventory I acquired in the 80's at Fram, the manufacturer of all the steel shaker components.
I still have some of the later small headed studs pictured.
