Wiring diagram needed #2688670
08/17/19 09:40 AM
08/17/19 09:40 AM
Midwest
O
On the edge 02 Offline OP
O
Midwest
Hi all, in search of a wiring schematic for 67 Chrylser 300 with 8track and 5 speaker wiring and reverb or equivalent model with the above. Just want to make sure I hook up speakers (- reverb) correctly and not wipe out a channel, speaker,fader, or crossover. Thanks for the input Rick.
PS harness going in b body 70 with newer 8 ohm speakers and Orignal speakers never had " Postive + or Negative - marked on them. Have looked at the 70 b body wiring schematic to compare to 67 harness and only a couple color wire changes
Re: Wiring diagram needed [Re: On the edge 02] #2688693
08/17/19 11:15 AM
08/17/19 11:15 AM
None
71rm23 Offline
71rm23  Offline
None
www.mymopar.com under tools/reference
Re: Wiring diagram needed [Re: 71rm23] #2688747
08/17/19 01:52 PM
08/17/19 01:52 PM
Midwest
O
O
Midwest
Thanks but none of their diagrams showed radio/ tape player wiring. Could a test light be hook up to see power comming out to find Postive + ?, electrical gurus or do I risk destroying a channel?
Re: Wiring diagram needed [Re: On the edge 02] #2688748
08/17/19 01:59 PM
08/17/19 01:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What color are the speaker wires.They should be standard as to pos and neg.Test light won't work.
Re: Wiring diagram needed [Re: stumpy] #2688783
08/17/19 04:20 PM
08/17/19 04:20 PM
Midwest
O
O
Midwest
Been spending the day researching the c body harness vs b body 70 vs e body 70 and it appears the radio might be the culprit but she's out and going to verify and hopefully be rebuilt and updated. Thanks for all the replies guys. Great people and great site as always!!!
Re: Wiring diagram needed [Re: On the edge 02] #2688804
08/17/19 05:22 PM
08/17/19 05:22 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Speaker polarity only matters so that all speakers are phased the same, otherwise you take the risk of some of the sound being cancelled out (one speaker moving in while the other it moving out).
Re: Wiring diagram needed [Re: Jim_Lusk] #2688814
08/17/19 05:45 PM
08/17/19 05:45 PM
Midwest
O
O
Midwest
Thanks Jim. Didn't you own a BLK 71 Cuda?
Re: Wiring diagram needed [Re: On the edge 02] #2689260
08/19/19 01:05 AM
08/19/19 01:05 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Nope. Might be one of the other Jim Lusks. Was it blown from NY state?
