Duster Pistol Grip? #2688385
08/16/19 11:57 AM
08/16/19 11:57 AM
midwest - USA
69/70 Plymies Offline OP
midwest - USA
Came across an "original" 1970 Duster 340 4 speed with a pistol grip shifter. Did someone add this shifter or were these factory original shifters in the Dusters? Another question.....Are these cars very desirable? Thanks for your input.
Re: Duster Pistol Grip? [Re: 69/70 Plymies] #2688393
08/16/19 12:37 PM
08/16/19 12:37 PM
Sounds like someone installed the top part(shifter handle) of a E or B body shifter in that car, no pistol grip OEM shifters in A bodies in 1970 or later I believe twocents
As far as who and how many people likes them it depends work
I like them a lot, but I've always been speed needy devil up
What condition is it in?
Re: Duster Pistol Grip? [Re: Cab_Burge] #2688398
08/16/19 12:50 PM
08/16/19 12:50 PM
midwest - USA
midwest - USA
The car is very solid and 95%+ original condition. Just a little rust started ahead of the rear wheel wells.
Re: Duster Pistol Grip? [Re: 69/70 Plymies] #2688404
08/16/19 01:10 PM
08/16/19 01:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
No factory pistol grips in A-bodies, as far as I know, which kinda seems odd.
Shifter swap may indicate other changes from original, which may or may not be a factor for you.
Heck yeah, 340 Dusters are desirable, especially with 4-speeds.
Many feel that '71 is the best year, but '70s have a fan base for sure.
Check the spare tire well & rear body panel below the tail lamps.
Post some photos if you can.
Re: Duster Pistol Grip? [Re: 69/70 Plymies] #2688409
08/16/19 01:20 PM
08/16/19 01:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
NO pistol Grips for the A bodies, That's a B/E body thing only, although there's nothing wrong with adding one to any vehicle
Re: Duster Pistol Grip? [Re: DAYCLONA] #2688411
08/16/19 01:23 PM
08/16/19 01:23 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
The 71 to 74 bench seat pistol grip shifter handle works nicely in an A body.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Duster Pistol Grip? [Re: chargervert] #2688558
08/16/19 09:07 PM
08/16/19 09:07 PM
CA
crackedback Offline
crackedback  Offline
CA
I agree. Works well.
