Re: Where Do I Look?
[Re: Mopar Sam]
#2688318
08/16/19 08:48 AM
08/16/19 08:48 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
I've seen old strut rod bushings deteriorate to nothing and cause this. ONCE, a VERY long time ago I came across a '65 Belvedere with loose steering box bolts.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Mopar Sam]
#2688522
08/16/19 07:36 PM
08/16/19 07:36 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Have your wife/someone get in the drivers seat and wiggle the wheel form side to side and you look under the front end at the steering/front end parts and see where the play is........replace parts w play....done.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2688543
08/16/19 08:36 PM
08/16/19 08:36 PM
Posts: 53 Sullivan, IN
Mopar Sam
Sullivan, IN
Have your wife/someone get in the drivers seat and wiggle the wheel form side to side and you look under the front end at the steering/front end parts and see where the play is........replace parts w play....done. That is how I found the worn pitman and idler arms. I will have one of my sons get under it this weekend while I move the wheel. Maybe I'm just not seeing the problem.
[Re: b1dartsport]
#2688737
08/17/19 01:20 PM
08/17/19 01:20 PM
Posts: 15,911 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I think the suggestions of bad tire are good ones, since nothing else seems to be the issue so far, although the few I've had usually cause a pull. Bad strut or shock in older car would definitely cause this.
Facts are stubborn things.
