1971 W100 instrument bezel #2687664
08/14/19 12:17 PM
08/14/19 12:17 PM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
I am trying to figure out how to get the guage and speedometer panel off of the plastic instrument bezel/faceplate. It's got me stumped. I see no screws holsing the two pieces together.
Re: 1971 W100 instrument bezel [Re: superwrench] #2690315
08/22/19 11:57 AM
08/22/19 11:57 AM
Nobody ever taken one apart??
Re: 1971 W100 instrument bezel [Re: superwrench] #2690535
08/23/19 07:53 AM
08/23/19 07:53 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
I can't really picture what you are referring to.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 1971 W100 instrument bezel [Re: superwrench] #2690653
08/23/19 02:39 PM
08/23/19 02:39 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
IIRC, there are some snap rivets that hold it together. They simply pop out.
Re: 1971 W100 instrument bezel [Re: TC@HP2] #2692856
08/30/19 11:26 AM
08/30/19 11:26 AM
...I don't see any snap rivets....not like the B body lense/cluster ones anyways. The metal instrument frame is stuck HARD to the plastic bezel...maybe some hidden screws??? Bizare...
Re: 1971 W100 instrument bezel [Re: superwrench] #2692873
08/30/19 12:09 PM
08/30/19 12:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Post a picture of it and we'll see what we can advise.
Re: 1971 W100 instrument bezel [Re: stumpy] #2693018
08/30/19 09:26 PM
08/30/19 09:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Its been a long time....I think the bezel has flat tabs on the back that insert into metal clasps that grab the tabs. You need to pry the bezel out a little at each tab until all are out a little, the repeat, maybe 3-4 times. When the tabs break off, there is nothing that will hold the bezel in place, so don't break them all off. I want to say there are 6 or 8 tabs, but like i said, it was a long time ago. Gene
Re: 1971 W100 instrument bezel [Re: poorboy] #2693624
09/02/19 12:10 PM
09/02/19 12:10 PM
That makes sense now Gene...because there certainly isn't anything visible that one could undo/remove. I'll pull it back out of the truck and see. Thanks.
