05 ignition switches #2687310
08/13/19 03:31 PM
08/13/19 03:31 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
My 05 ram ignition switch is not working it will not let the ac fan work unless it’s in the exactly correct position and sometimes it turns off when you hit a bump. I’ve narrowed it down to the switch and it is discontinued at Mopar it cost almost 400 new when it was available. Wow. Most of the ones I’ve found at the wrecking yard, are not much better. They all look burned on the two main posts. Any ideas?
Re: 05 ignition switches [Re: fastmark] #2687334
08/13/19 04:16 PM
08/13/19 04:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 05 ignition switches [Re: stumpy] #2687348
08/13/19 04:47 PM
08/13/19 04:47 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks. Dealer price when they carried it was 350 plus, summit had oem for 250 plus. I could not find it by application on rock auto. Found it at O’riellys in stock for 34.00. Now that I have the part no from standard us351, they are 20 bucks online. Go figure.
Re: 05 ignition switches [Re: fastmark] #2687384
08/13/19 06:18 PM
08/13/19 06:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's why I always do a general online search before buying anything.
Re: 05 ignition switches [Re: fastmark] #2687532
08/14/19 07:57 AM
08/14/19 07:57 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well I went back to rock auto and found it right off. Must have been brain dead when I looked the first time I looked.
