Spark plug life #2686944
08/12/19 04:42 PM
08/12/19 04:42 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Just curious as to what this gang thinks about plug life. How many runs, or time?
I have a about 100 passes in two years on mine and probably should change them, but see no real reason. We are going mid 10's on a big block and they look fine.
What do you think?
Re: Spark plug life [Re: SportF] #2686949
08/12/19 04:59 PM
08/12/19 04:59 PM
tboomer Offline
tboomer  Offline
Tom...How old and what kind of plug wires are you using? wave
Re: Spark plug life [Re: SportF] #2686950
08/12/19 05:05 PM
08/12/19 05:05 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
My NGK's were installed in the fall of 2015. I have maybe 100 street miles and about 150-200 passes. The car starts fine, idles clean and my et's don't fluctuate. When I detect a slight miss at idle or the car seems to load up at start up is when I change mine.
Ok
Re: Spark plug life [Re: tboomer] #2686952
08/12/19 05:13 PM
08/12/19 05:13 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Good point. Accel super stock. I'll wring them out to see what kind of ohms I have.
I don't remember how old. hummm
Re: Spark plug life [Re: SportF] #2686962
08/12/19 05:41 PM
08/12/19 05:41 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
4th race season for my ar3911’s and my ultra40 wires. Might put a new set over the winter if I rebuild the engine
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Spark plug life [Re: SportF] #2686964
08/12/19 05:46 PM
08/12/19 05:46 PM
What ignition and plug gap?
My thoughts are if it ain't broken, don't fix it tsk
I use to change plugs at the track after every race, I would leave the old ones in it to warm the car up in the pits and then put the new ones in realcrazy
I had cans of spark plugs that had from 10 to 16 runs on them shruggy
Once I switched to the MSD race gold ignition boxes and their matching coil I didn't need to do that anymore boogie
Re: Spark plug life [Re: pittsburghracer] #2686965
08/12/19 05:46 PM
08/12/19 05:46 PM
Renton Washington
Triple Threat Offline
Renton Washington
I'm on this program, change plugs when i rebuild the engine every 400-500 runs. There's 16 of them!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Spark plug life [Re: Cab_Burge] #2686970
08/12/19 05:52 PM
08/12/19 05:52 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
MSD digital 6AL, .035 on the plug gap
I see a lot of folks like Cab used to do, changing plugs all the time, and it just gets one to thinking.
I'm going to change these, but not because they need it. Because I have them out.
Re: Spark plug life [Re: SportF] #2686972
08/12/19 05:55 PM
08/12/19 05:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Many 100 run seasons. Still ET/MPH the same as when they were new.
Doug
Re: Spark plug life [Re: dvw] #2686998
08/12/19 07:04 PM
08/12/19 07:04 PM
Washington
madscientist Offline
Washington
Depends on the plug and how it was designed. I'd much rather use an easy to fire, much fewer run plug than use something that is designed to go 50 or 100k miles. Plugs are cheap.
Re: Spark plug life [Re: madscientist] #2687002
08/12/19 07:08 PM
08/12/19 07:08 PM
PA.
"Little"John
"Little"John
PA.
An old Mopar mechanic 40 years ago told me after I had issues with Champion plugs to throw them in the trash, buy some Autolite plugs, gap them at .028-.030, put them in and go race. Still doing it, still working good.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Spark plug life [Re: SportF] #2687018
08/12/19 07:57 PM
08/12/19 07:57 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I typically get two years out of mine.....I keep running them if the electrode holds up....
Re: Spark plug life [Re: Dragula] #2687031
08/12/19 08:23 PM
08/12/19 08:23 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I run autolites ar3911 change out at the beginning of the season just for the heck of it. But for $30 once a year why not.
Just had a $50 coil go bad and quit without warning, around 5 yrs old for it.
changing out the inexpensive parts every so often might not be a bad idea.
Re: Spark plug life [Re: nss guy] #2687056
08/12/19 09:09 PM
08/12/19 09:09 PM
Otsego, mi. by Martin 131 stri...
JT612GTX Offline
JT612GTX  Offline
Anybody out there using the E - 3 plugs? the pro guys claim they use them, probably just for advertising purposes.
Thought about trying them but are they worth the price? ive had good luck using NGK race plugs and autolite.....
86 Daytona - 612/ glide - 2400lbs - 8.60 alot more left
71 S/G Challenger - 469/glide - 2800lbs - 9.20s and tuning
70 Challenger - mild 440/727 - 3475lbs - 10.96 best
70 GTX - future quick 16? more $$$$$$
Re: Spark plug life [Re: JT612GTX] #2687152
08/13/19 08:26 AM
08/13/19 08:26 AM
an8sec70cuda Offline
I used to run them a long time in my cuda...at least a year or more. No reason to change them all the time. I use NGK plugs and MSD 6AL boxes on all my cars. Plug wires vary, never had a set that didn't run good, some just fit much better than others.
The E3 plugs are a joke...along w/ every other "revolutionary" plug design. There's so much snake oil in the ignition products market it's ridiculous...plugs AND wires. There a lot of gimmick parts out there, but the ignition system market seems to be saturated with them. Maybe I shouldn't say "gimmick", but a lot that work fine, just never live up to their hype.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Spark plug life [Re: an8sec70cuda] #2687162
08/13/19 08:52 AM
08/13/19 08:52 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had 4 Drag weeks on my AR3911s, when I put my new motor in I forgot to buy plugs so I took the ones from my 360 and moved them to the 416. So four drag weeks with two motors haha. They still looked good but started to show a little wear, and I just freshened up the top end so I changed them out.
68 Barracuda Formula S 340
Re: Spark plug life [Re: SportF] #2687262
08/13/19 01:45 PM
08/13/19 01:45 PM
I use a dental 10X magnifeyer to look at my plugs closely,, I do replace them when the center ground electrode gets rounded off from wear or it is wearing on a angle to the ground strap shruggy
I do see what looks like slag or metal hanging off to one side of the center electrode also when the motor is to lean making the plugs do that shock down
Get a good magnifer to help you get a good close look at your plugs and then decide scope
Re: Spark plug life [Re: Cab_Burge] #2687265
08/13/19 01:50 PM
08/13/19 01:50 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
How can you call it a "race engine" and leave plugs in for so long?? LOL
Plugs tell you all about whats going on in there...
Run some nitrous , and you will go through a lot of plugs...LOL
....BAD A$$ STREET CAR.....
Re: Spark plug life [Re: n20mstr] #2687268
08/13/19 01:56 PM
08/13/19 01:56 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I usually change the plugs whenever I freshen the motor up after 400ish passes. I run autolites in my cars.
Re: Spark plug life [Re: n20mstr] #2687276
08/13/19 02:07 PM
08/13/19 02:07 PM
I switch to E85 5 yrs ago, that stupid fuel seems to be VERY sensitive to the plug heat range, but that being said I ended up switching motor parts which led to R&D problems in the valve train that I may have interpreted as spark plug problems. Same deal on the new motor with a goofy distributors and some bad ignition parts, I hate motor problems(race car or any other vehicle problems) rant whiney
Time to take a step back and really focus on this rascal to get rid of those type problems wrench work grin
