Head bolts #2686790
08/12/19 10:09 AM
08/12/19 10:09 AM
Jacksonville, Fl
426runner Offline OP
Jacksonville, Fl
How many times would you use a set of head bolts? Would it strictly be based on # times torqued down? Can you factor how little run time on the engine before removing the heads?
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Head bolts [Re: 426runner] #2686806
08/12/19 10:40 AM
08/12/19 10:40 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would use them as many times as you want. That last question I don't understand.
2011 Drag Pak Challenger
Re: Head bolts [Re: rickseeman] #2686833
08/12/19 11:24 AM
08/12/19 11:24 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Since the OP doesn;t mention what engine, or what brand headbolts, the answer is, it depends.
If they are tor to yield then you not supposed to reuse them. Though I have.
If they are out old school style head bolts, or aftermarket stuff like ARP, then they are reuseable indefinitely as long as you don't over stretch them.
Re: Head bolts [Re: Sniper] #2686836
08/12/19 11:30 AM
08/12/19 11:30 AM
Jacksonville, Fl
Jacksonville, Fl
426, ARPs... Thanks!
Re: Head bolts [Re: 426runner] #2686843
08/12/19 11:42 AM
08/12/19 11:42 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think your grandkids can use them.
Re: Head bolts [Re: 426runner] #2686844
08/12/19 11:45 AM
08/12/19 11:45 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
From ARP:
Are ARP bolts and studs re-usable?
Yes. As long as the fasteners have been installed and torqued correctly, and show no visible signs of damage, they can be re-used. If they show any signs of thread galling or corrosion, they should be replaced. In the case of rod bolts, if any of them have taken a permanent set and have stretched by .001” or longer, you should replace them immediately. See page 29 in the catalog for more detailed information on this critical measurement.
