Fusible link blew on new harness
#2686332
08/10/19 07:13 PM
08/10/19 07:13 PM
Posts: 53 Fort Collins, CO
justintyme
Fort Collins, CO
I'm not great at electrical so I need some advice. 69 Roadrunner, new engine harness 2 yrs ago, last year the dash harness melted and caught fire at the fuse box, had a lot of crappie splices, chafes but was running fine.
installed new dash harness this week, everything seemed to be working fine, had the car running a bit yesterday then hooked up my tach and accessory gauges to new fuse box today. again all seemed fine with the car not running, had key on for a bit and gauges lit up. cleaned up and started car for maybe 10 seconds and fusible link at the bulkhead went up in smoke. gotta get a new one, and I unhooked the gauges I hooked up today. So do i need to figure out if something is drawing to much in the car? or can a bad voltage regulator say put out to much juice and fry it?
Re: Fusible link blew on new harness
[Re: justintyme]
#2686357
08/10/19 08:47 PM
08/10/19 08:47 PM
RapidRobert
So do i need to figure out if something is drawing to much in the car? yes, dead short to ground somewhere
[Re: justintyme]
#2686378
08/10/19 11:37 PM
08/10/19 11:37 PM
moparpollack
Lil Herman
Lil Herman
85086
Check these out:
Make sure harness bulkhead is seated, not loose, ammeter lugs aren't loose, switch connector, short in the alternator.
[Re: justintyme]
#2686380
08/10/19 11:47 PM
08/10/19 11:47 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
installed new dash harness this week, everything seemed to be working fine, had the car running a bit yesterday then hooked up my tach and accessory gauges to new fuse box today. again all seemed fine with the car not running, had key on for a bit and gauges lit up. cleaned up and started car for maybe 10 seconds and fusible link at the bulkhead went up in smoke. gotta get a new one, and I unhooked the gauges I hooked up today. So do i need to figure out if something is drawing to much in the car? or can a bad voltage regulator say put out to much juice and fry it? A dead or faulty shorted cell in a battery with a reman alternator that puts out 55-60 amps vs the stock 37 will do this. It is smart to run a 6 gauge wire from the alternator stud to the battery cable, with a fuse or 10 gauge fuse link, if you have a high output alternator....most remans just default to a 60 amp, couple that with an old battery and poof. So yes, regulator could fail, and full field a high output alternator into a low charge, or bad battery and fry that link in 10 seconds, with stock wiring that has nothing wrong with it. Fuse link is the safety valve.
[Re: justintyme]
#2686488
08/11/19 12:56 PM
08/11/19 12:56 PM
Posts: 669 Los Osos, Ca
CKessel
Los Osos, Ca
Get a factory wiring diagram for your car and make sure the terminals are in their proper cavity. Years ago on my 73 Duster, I found some were not where they were supposed to be on both sides on the bulkhead unit. I switched them out to make them correct. Maybe one or more of yours on the new unit is where its supposed to be but the opposite end is not.
Carl Kessel
[Re: justintyme]
#2686530
08/11/19 03:20 PM
08/11/19 03:20 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
thanks for the info guys, I am getting a new link and will update when I on HD it, either that tach has a short, or the battery was low cranking this time, it has been sitting a year and had a charger on it when cranking as it had run down after initially charging it over might, which I attributed to having the dome lights etc on while working in installing stuff You're playing with fire here. There is a short to ground. The only reason a good fusible link burns quick is when too much current is flowing through it. A dead battery and a high charging rate should not melt it. At idle, even a 60 amp alternator is only going to supply 30 amps or so. Read this. http://www.heritech.org/cuda/Charge2.htmlYou can use the '67 schematic for general guidance. '69 is going to have different connector cavities, a few different colors, and some other differences. But essentially the flow paths are the same. For trouble shooting, you can connect a blinker modual as a circuit breaker instead of wasting fusible links and also risking other components. Another method, which could be used in conjunction with the circuit breaker, is to wire a couple of leads on a light bulb. The wattage of the lamp will restrict the current and you'll see there is a problem. Start with the battery side. key off, doors closed, lamp should be off. If not look for the short ground in the main circuit.
[Re: justintyme]
#2686664
08/11/19 10:23 PM
08/11/19 10:23 PM
Mattax
Phila. Pa.
All it takes is one wire accidently scrunched down or rubbing against the body metal. Service manual is best. '69 B Body I'm not that familiar with. Schematically, it will be almost the same as any late 60s A or B body. There was definately some change in the connections, and I think the tach wire may have been run through a grommet in the firewall? Could do a resistance check of the coil itself. Primary connections should be open to ground. Not sure if you looked through the link above. It should be helpful. But for a general scheme of the main circuit (power feeds and everything connected to them) this will be what you want to make up or alter the details for your car. First one doesn't include the start circuits. If there's no probelm in them, its easier to leave them off the schematic. Key in RUN, both Ignition 1 (Run) and Accessory feeds get power from the switch. Accessory includes power to flashers, windshield wipers, and two or three circuits with fuses.
