Six pack manifold height
#2686280
08/10/19 03:04 PM
08/10/19 03:04 PM
Posts: 670 Third rock from the sun.
busboy
Just got the six pack/carbs mounted on the 440 in the car (70’ Bee) for the first time. With the air cleaner and cover on there’s interference with the hood, raises the back of the hood about 1/2” when it’s closed. Intake is an Eddy CH6. Is this a taller intake than the stock cast one? Does anyone have dimensions for big block six pack intakes?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Six pack manifold height
[Re: busboy]
#2686289
08/10/19 03:45 PM
08/10/19 03:45 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Just got the six pack/carbs mounted on the 440 in the car (70’ Bee) for the first time. With the air cleaner and cover on there’s interference with the hood, raises the back of the hood about 1/2” when it’s closed. Intake is an Eddy CH6. Is this a taller intake than the stock cast one? Does anyone have dimensions for big block six pack intakes? The RB intakes are the same height "factory" or aftermarket replacement, I'll assume you have the twin scoop hood?, and not the powerdome?, is the air cleaner hitting a brace under hood?, running an under hood pad? Mike
[Re: 4406bbl]
#2686496
08/11/19 01:16 PM
08/11/19 01:16 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Not the best pic, but the whole center brace is cut out, circular shape at ends like it was cut with snips or power shears. Mine was clean with no glue there. 4bbl sbirds have this brace intact. I must be missing something here,original 6bbl bird,original hood,I have no clearance issues,no cut bracing and what is there is not even close.
[Re: 62maxwgn]
#2686554
08/11/19 04:29 PM
08/11/19 04:29 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Not the best pic, but the whole center brace is cut out, circular shape at ends like it was cut with snips or power shears. Mine was clean with no glue there. 4bbl sbirds have this brace intact. I must be missing something here,original 6bbl bird,original hood,I have no clearance issues,no cut bracing and what is there is not even close. Look real close 62, in the center where the peak of the hood is there was a brace front to rear covering that peak, you can see the trimming on the front side of your hood, where the round spot is in the center yours is trimmed. 4bbl birds have about a 4"wide brace there. Thanks 62, I knew you would come thru with a great pic. Now that you know you will be checking out sbird hoods at the shows.
[Re: 62maxwgn]
#2686559
08/11/19 04:56 PM
08/11/19 04:56 PM
4406bbl
Nebraska
Not the best pic, but the whole center brace is cut out, circular shape at ends like it was cut with snips or power shears. Mine was clean with no glue there. 4bbl sbirds have this brace intact. I must be missing something here,original 6bbl bird,original hood,I have no clearance issues,no cut bracing and what is there is not even close. 4bbl hood, not mine
[Re: 4406bbl]
#2686684
08/11/19 11:42 PM
08/11/19 11:42 PM
62maxwgn
Blair County,PA
Not the best pic, but the whole center brace is cut out, circular shape at ends like it was cut with snips or power shears. Mine was clean with no glue there. 4bbl sbirds have this brace intact. I must be missing something here,original 6bbl bird,original hood,I have no clearance issues,no cut bracing and what is there is not even close. Look real close 62, in the center where the peak of the hood is there was a brace front to rear covering that peak, you can see the trimming on the front side of your hood, where the round spot is in the center yours is trimmed. 4bbl birds have about a 4"wide brace there. Thanks 62, I knew you would come thru with a great pic. Now that you know you will be checking out sbird hoods at the shows. Now that you know you will be checking out sbird hoods at the shows. not really !!
[Re: 4406bbl]
#2686694
08/12/19 12:29 AM
08/12/19 12:29 AM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
Not the best pic, but the whole center brace is cut out, circular shape at ends like it was cut with snips or power shears. Mine was clean with no glue there. 4bbl sbirds have this brace intact. I must be missing something here,original 6bbl bird,original hood,I have no clearance issues,no cut bracing and what is there is not even close. Look real close 62, in the center where the peak of the hood is there was a brace front to rear covering that peak, you can see the trimming on the front side of your hood, where the round spot is in the center yours is trimmed. 4bbl birds have about a 4"wide brace there. Thanks 62, I knew you would come thru with a great pic. Now that you know you will be checking out sbird hoods at the shows. 1970 Coronet RT hood
[Re: 4406bbl]
#2686858
08/12/19 12:07 PM
08/12/19 12:07 PM
62maxwgn
Blair County,PA
There you go, proven wrong again. All I know is every 6bbl bird I have been around is cut, hemi bird a buddy had was cut, 4bbl birds were not. His hood will not close, remove the brace and it will. It is also real smart to tie the engine down on these, put some clay on the air cleaner and close the hood to see why. Went back and looked again,absolutely no sign of any cutting on inner structure,it is as stamped including the section under the added on top extension.
[Re: 62maxwgn]
#2686874
08/12/19 12:56 PM
08/12/19 12:56 PM
4406bbl
Nebraska
There you go, proven wrong again. All I know is every 6bbl bird I have been around is cut, hemi bird a buddy had was cut, 4bbl birds were not. His hood will not close, remove the brace and it will. It is also real smart to tie the engine down on these, put some clay on the air cleaner and close the hood to see why. Went back and looked again,absolutely no sign of any cutting on inner structure,it is as stamped including the section under the added on top extension. No your hood is not as stamped, or it would look like the green hemi hood, or the yellow 4bbl hood, you cannot see the center peak on those. I can see the cut at the front center of the orange hood plain as day in your pic. Your hood has no center bar. I found this out fixing a 6bbl superbird in my bodyshop in 1981, got a nos hood, had to cut the bar. I assumed all hemis were done, but obviously not. It is one of those things I usually keep my mouth shut about to avoid the fight. I got to repaint that hood back then because it would not close when the car was done, you do not forget stuff like that. Its all good its how we learn.
