37 plymouth #2685803
08/08/19 07:48 PM
08/08/19 07:48 PM
New Kent, Va.
bobbyb Offline OP
bobbyb  Offline OP
New Kent, Va.
Hello, I'm trying to start a 37 plymouth that has been sitting for about 15 years. Original motor, inline 6, gas tank and fuel lines are clean. Pour gas in carb and it will start and run a few seconds, hooked up a electrical pump with same results, wants to run but just dies. Any help will definitely be appreciated.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: 37 plymouth [Re: bobbyb] #2685830
08/08/19 09:10 PM
08/08/19 09:10 PM
E
earlymopar Offline
earlymopar  Offline
E
If you remove the air cleaner from the carburetor and move the linkage (engine not running) do you see fuel squirting? I would suspect a plugged jet.
- EM
Re: 37 plymouth [Re: earlymopar] #2685847
08/08/19 10:19 PM
08/08/19 10:19 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Runs, then dies suggests fuel (spark is usually all or nothing).
I'd suggest cleaning the carb carefully.
I hope you cleaned the oil pan and checked the pickup, lubed the cylinders and checked for oil pressure too.
I would hate for a minor problem to cause a major problem when running.
Also, if running it for a while, keep an eye on temps.
The water distribution tube is a common failure on old sitting engines.
http://p15-d24.com/forum/20-technical-archives/
Remember, those older engines run well when properly maintained, they just need more maintenance than even 1960s engines. Waking one after years takes a bit of effort!
Re: 37 plymouth [Re: RodStRace] #2685986
08/09/19 11:32 AM
08/09/19 11:32 AM
moparx Online content
moparx  Online Content
could you post some pics of this car please ? always nice to see other's projects.
beer
Re: 37 plymouth [Re: bobbyb] #2688859
08/17/19 07:18 PM
08/17/19 07:18 PM
Plano, TX
hkestes Offline
hkestes  Offline
Plano, TX
Think RodStRace has given you some good advice.
Here is some inspiration. My 37 Plymouth coupe and the 230 flathead that I built for my 48 Plymouth coupe. It was my daily driver for about 5 years in Dallas traffic. The flatheads can be very reliable if in good condition.
Yours should be a 201 (82 HP). A 218 (95 HP) from a late 40s or a 230 (132 to 138 HP) from a mid to late 50s would be allmost a bolt in for you with the right bellhousing and starter. Either would offer a good boost in performance. I know when I went from my original 218 to the 230 there was a big seat of the pants improvement. Another think I would suggest is a Borg Warner R6 overdrive transmission. I put an R10 in my 48 and it was the single best modification I made to the car.
Video Still.png388880-1338008775-f88b30d420c5accacd6b5e95912761d6.jpg1904382-98a2a0930e431689cb886816c276eb91 (1).jpg
