Transmission problem #2684848
08/06/19 02:06 AM
08/06/19 02:06 AM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
93 5.2 4 X4 Dakota rebuilt trans 3 years ago. Last week out of nowhere, while shifting from 2nd to 3rd it felt like something was holding the truck back. Something was keeping it from accelerating & shifting into 3rd. This truck is always driven in 2 wheel drive. The next day everything is fine except reverse is slipping real bad, fluid level is good. HELP !
Re: Transmission problem [Re: 72sat] #2684905
08/06/19 10:00 AM
08/06/19 10:00 AM
montana
BANDIT Offline
BANDIT  Offline
montana
Just curious, who rebuilt it?
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Transmission problem [Re: 72sat] #2684987
08/06/19 02:06 PM
08/06/19 02:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The front clutch is used in both 3rd and Reverse. Sounds like leakage from seals/sealing rings.
