Trouble starting after driving #2683994
08/03/19 10:54 AM
08/03/19 10:54 AM
Tampa Bay
BadFishy Offline OP
BadFishy  Offline OP
Tampa Bay
Hi, I just noticed a problem with my car. Easily starts from cold, even after a few days or weeks of not driving. But what I've noticed recently is that after I drive it, even for 15 minutes, and stop the engine, then try start again right away, it has a lot of trouble turning over. 6 - 8 attempts later it finally starts, but just barely. Any ideas? Thanks in advance!
1971 Cuda, 440 custom-build
Re: Trouble starting after driving [Re: BadFishy] #2684020
08/03/19 11:49 AM
08/03/19 11:49 AM
moparx Offline
moparx  Offline
if not cranking when hot, there could be multiple electrical issues, including wiring, connections, battery cables, bulkhead connections, etc.
what car is this ? any other symptoms ?
the more info we have, the better chance we have of helping you conquer your difficulties.
beer
Re: Trouble starting after driving [Re: moparx] #2684151
08/03/19 07:38 PM
08/03/19 07:38 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
So when you say trouble turning over, barely turns over, you do mean as if the battery is drained, correct? So definitely not a fuel issue.
Facts are stubborn things.
Re: Trouble starting after driving [Re: larrymopar360] #2684157
08/03/19 08:06 PM
08/03/19 08:06 PM
Indiana
68_661charger Offline
Indiana
Timing too far advanced? They get hard to crank over when warm.
Re: Trouble starting after driving [Re: 68_661charger] #2684159
08/03/19 08:14 PM
08/03/19 08:14 PM
What Larry said, turns over slow or turns over OK but wont light off? Pull the coil wire out of the dist cap & ground it on the intake & if it now cranks over OK then it is timing.
Re: Trouble starting after driving [Re: BadFishy] #2684279
08/04/19 11:07 AM
08/04/19 11:07 AM
central il.
second 70 Online content
second 70  Online Content
central il.
Could be as simple as weak battery . Heat will make an old battery not start a car it will easily start cold.
Re: Trouble starting after driving [Re: second 70] #2684513
08/05/19 12:26 AM
08/05/19 12:26 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
During this scenario of will not start. Does a boost help?
Sounds like battery, battery wires or starter.
Re: Trouble starting after driving [Re: Magnum] #2684539
08/05/19 06:40 AM
08/05/19 06:40 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I just had this problem with My 67 , had the battery checked and was told it checked good. After checking everything else changed the battery and no more problem.
Re: Trouble starting after driving [Re: BadFishy] #2701456
09/27/19 04:13 PM
09/27/19 04:13 PM
St. Louis area
MrBill Offline
MrBill  Offline
St. Louis area
Fought this problem for years on my 73 340 Cuda. Tried many different starters, batteries, etc . Seemed my engine was "tight" when hot , but spun easily when cold. Thought heat was getting to the starter from headers or the alternator was cooking the battery. Finally solved when I changed the perfect-looking stock-type-but-aftermarket positive battery cable. It had corroded under the insulation and within the battery post connector thus causing a resistance to current flow. I built my own cables from some excellent salvaged jumper cables and soldered copper lugs for the connections at both the starter, engine block and battery post connectors. No more problems.
oooOOOH NOOOooo MrBill MOPAR or NOCAR
Re: Trouble starting after driving [Re: MrBill] #2701680
09/28/19 11:26 AM
09/28/19 11:26 AM
moparx Offline
moparx  Offline
i too, have run into bad battery cables as you described. on both the positive battery cable, as well as the solenoid to relay wire.
anytime a hot start issue is had, the first thing i encourage is to check for voltage drop on both of those wires, then go from there.
this mostly occurs from using those "bolt on" battery cable ends [did i ever mention i HATE those things ? grin] which invite moisture to creep into the positive cable, causing corrosion inside the cable you can't see.
beer
Re: Trouble starting after driving [Re: moparx] #2701761
09/28/19 03:19 PM
09/28/19 03:19 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
beer
iagree
Re: Trouble starting after driving [Re: 451Mopar] #2702544
10/01/19 10:15 AM
10/01/19 10:15 AM
Halifax, VA.
moparjack44 Offline
moparjack44  Offline
Halifax, VA.
beer
iagree
I also agree. Starter gets hot from the exhaust or sorry battery cables. Believe it or not, sorry ground causes a lot more problems than the postive connections.
Jack
K.I.S.S.
Re: Trouble starting after driving [Re: moparjack44] #2702564
10/01/19 10:54 AM
10/01/19 10:54 AM
moparx Offline
moparx  Offline
absolutely. as the saying goes : "you can't have too many grounds."
they are VERY important in the scheme[matics] of things. biggrin [a little 'lectric humor there]
beer
Re: Trouble starting after driving [Re: moparx] #2702606
10/01/19 12:49 PM
10/01/19 12:49 PM
Halifax, VA.
moparjack44 Offline
moparjack44  Offline
Halifax, VA.
beer
up beer
Jack
K.I.S.S.
