Re: 8 3/4 vs. Dana 60 [Re: Cab_Burge] #2683225
07/31/19 09:08 PM
07/31/19 09:08 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I build lots of rears in my little one man shop. Parts are expensive so you only want to do this once. Getting used parts is a crap shoot. Building a Dana from a truck can be done but it is time consuming and can be done wrong. I’ve got a Dana in the shop right now that was not set up properly but it was still working. I would hate to have bought it as a good unit then opened it up to have to rebuild it. I don’t like spending money twice. They are one tough rear end, though. I’ve had plenty of 8 3/4 that have not faired that well even with street use. The rear end you need is for a 71 up b body and is a little more difficult to find in any form but an oem Dana is kinda rare. But not in high demand like an ebody so they don’t bring the ebody price tag with it. HOWEVER, I just happen to have something that might interest you. It’s an original 72 b body Dana 60 that has not been modified. As a matter of fact, it has been completely restored. I got it in parts deal so I don’t have the big dollars in it that the original purchaser did. It has everything new, axles brakes, sure grip, 3.54 gears and even powder coated. It was built by DoctorDiff. It is a first class unit and ready to bolt in. If you are interested, PM me and we can talk.
Re: 8 3/4 vs. Dana 60 [Re: fastmark] #2683262
07/31/19 10:12 PM
07/31/19 10:12 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I can't tell you what better suits your car, but I can share what it cost me to build a Dana.
Got one off of Craigslist that was pulled from an 83 F250. All in it was about $2600 with all new parts except the ring and pinion and included disc brakes.
Re: 8 3/4 vs. Dana 60 [Re: an8sec70cuda] #2683270
07/31/19 10:35 PM
07/31/19 10:35 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by an8sec70cuda
Originally Posted by csk
Originally Posted by DAYCLONA
Originally Posted by lewtot184
I've shucked 8 3/4 ring and pinions with a 383 4spd. maybe an 8 3/4 will hold up; maybe not. a lot of factors to consider. if you do an 8 3/4 and rip it the initial cost and repairs will be more than the initial cost of a dana.
Same here, I've toasted quite a few 8 3/4 rears, even behind a few 340/4spds's..... DANA 60, end of story
THIS ^^^^^^^^
iagree Build a Dana and you're done. Building a dana from a junkyard truck rear can be done cheap. Especially if you get one w/ the good track-lock diff. It'll have either 3.54 or 4.10s gears in it already most likely.
The one I put in my dad's road runner came from under an old dodge motorhome/camper van of some sort. Had the good track lock diff and 3.54s w/ a 1350 yoke surprisingly. All we did was narrow it, weld on pass. car ends and perches, and get some 35 spline axles from Dr. Diff. As well as his track-lock rebuild kit w/ the 35 spline side gears.
Backbraces and billet caps for an 8.75 are "feel good" parts. May make you feel better, but do nothing to keep it from shredding the ring and pinion.
Almost identical to my experience. Cut down Dana 60 from a truck, welded on car ends and used a spool and Dr. Diff axles. Under $1k total and ran identical to what the 8 3/4 did the week prior. I run 3.54's.
'63 Dodge 330
11.19 @ 121 mph
Re: 8 3/4 vs. Dana 60 [Re: GY3] #2683289
07/31/19 11:47 PM
07/31/19 11:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
A lot will depend on how the car is used also. I can tell you this that I bracket raced a 340 Dart back in the late 70's and early 80's. It was a 4-speed car and ran low 12's with a best ever et of 11.94 @ 113. Now when I launch a 4-speed car the gas pedal goes to the floor when the clutch comes out. In 4 years of racing the Dart I broke at least three 8-3/4 rears. Tore all the teeth of the ring gear once. Broke the pinion teeth once and broke the carrier once. Now fast forward to today and I have my 63 Sport Fury with the 8-3/4 rear in a heavier car. But my 63 is a 727 auto car. Its run 10.70's and it has never broke the 8-3/4 in it. I only race it about twice a year but its been on the road and raced some since 2011. The stick shift driveline is much harder on the rear if you run the car hard since it shocks the drivetrain. With an auto street car and street tires that don't hook the 8-3/4 should hold up fine. But with stickies it will depend and with a stick car it will be even worse. Ron
Re: 8 3/4 vs. Dana 60 [Re: jcc] #2683330
08/01/19 08:20 AM
08/01/19 08:20 AM
an8sec70cuda Offline
Except the end result of a failed cap is, a "shredded ring and pinion".
The gear fails first, resulting in the broken cap. The pinion deflects.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8 3/4 vs. Dana 60 [Re: an8sec70cuda] #2683342
08/01/19 08:44 AM
08/01/19 08:44 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Always?
If so, That means an upgraded Cap mod is essentially worthless? eek
Wonder if the OEM cap flexes at all, facilitating less then ideal R&P teeth loading, leading to their failure.
Re: 8 3/4 vs. Dana 60 [Re: jcc] #2683358
08/01/19 09:38 AM
08/01/19 09:38 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
If somebody gives you an 8-3/4 for free, go with it. If you are going to have to spend money, it's a Mopar, it looks better with a Dana under it.
2011 Drag Pak Challenger
Re: 8 3/4 vs. Dana 60 [Re: dfsmopars] #2683434
08/01/19 01:16 PM
08/01/19 01:16 PM
MA
K
Kevin Kowalski Offline
K
MA
Originally Posted by dfsmopars
Originally Posted by gtx6970
for me personally it would come down to gear choices. And theres not much for the Dana in something street / hiway friendly
But with an OD trans and a set of 3.54';s may not be bad for longer drives
The 3.55s in the 8.25 now are a bit too long. They were great with a 42RE I had in the car earlier but with the Tremec 70 mph and it’s only turning 1800 rpm. With the small block I have to wind it up to about 2000 rpm to leave from a stop light and not have to wait for the engine to take forever to catch up in order to shift to second. If that makes any sense.
I had a Tremec six speed with 4.10s in another car that was great. That’s why I think 3.91s would be a good gear with this five speed.
Can 3.91s be found for a Dana?
I couldn't get 3.91s for my S60 from Strange about 2 years ago. Talking with Strange and Dr. Diff, 3.91s are not available from most (or all?) gear manufacturers for the Dana 60 / S60. I heard that some 3.91s out there are not cut correctly and will at the very least exhibit excessive noise. I wanted to upgrade from a 3.73 8-3/4 in my e-body to a Dana and ended up settling for the 3.73s because I thought the 4.10s would be too steep. I rest well at night knowing the S60 can take anything I throw at it drag racing with a big block 4-speed.
Re: 8 3/4 vs. Dana 60 [Re: dfsmopars] #2683512
08/01/19 07:53 PM
08/01/19 07:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Originally Posted by Mr.Yuck
what is the car being used for? If you aren't frag racing dropping the hammer at 6k the 8.75 will be fine. If it makes you feel safer back brace it. Looks like a road racing car, a dana adds weight. My old 440-6 Charger went 11.20's @ 121+ had a 8.75 and 3.91's no issues at all. That was much more than 450...not too mention the added torque of a 440.
Well it’s a car that is a “jack of all trades and a master of none”. It has a full interior and tips the scale at 3900 lbs. Once a year on the strip and once on an auto cross. Never slicks. Has to be suited for out of state road trips. It is not shown at car shows but frequents regional cruise ins. It sometimes gets hammered pretty good on the streets when the coast is clear. It needs to gain the respect of serious car people whether at Mopar events, the Hot Rod Power Tour or Good Guys.
The hp and tq of the current small block will be increased to the goal of 450 for each power measurement hopefully after the rear end improvement. I am slow about making improvements since it is just a hobby but I will spend a little more dough to make the improvement the right one and not cheap out.
8.75 will be fine. Better yet save some money and get a Furd 9"
Coming soon!!!!
Re: 8 3/4 vs. Dana 60 [Re: dfsmopars] #2684367
08/04/19 04:38 PM
08/04/19 04:38 PM
Kentucky
dfsmopars Offline OP
Kentucky
I was given this today. If I could get a housing for $100 would it be a good build to spend the money on good content and run it on the street? Sure grip, 3.91 and disc brake conversion.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 8 3/4 vs. Dana 60 [Re: dfsmopars] #2684368
08/04/19 04:39 PM
08/04/19 04:39 PM
Kentucky
Kentucky
Inside
Re: 8 3/4 vs. Dana 60 [Re: dfsmopars] #2684812
08/05/19 10:25 PM
08/05/19 10:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Starting with a clean sheet of paper I would go with a 9" with NO FORD PARTS at all. Get a strong nodular center section from Strange and a Daytona pinion support and you will be fine with 35 spline axles and 4 pinion clutch style differential unit. twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: 8 3/4 vs. Dana 60 [Re: fourgearsavoy] #2684986
08/06/19 02:06 PM
08/06/19 02:06 PM
Minn
SportF Offline
SportF  Offline
Minn
[quote=fourgearsavoy]Starting with a clean sheet of paper I would go with a 9" with NO FORD PARTS at all. Get a strong nodular center section from Strange and a Daytona pinion support and you will be fine with 35 spline axles and 4 pinion clutch style differential unit. twocents
This is what the guys running in the 3's run. Next time at a big meet, look and see if I made that up. Actually, you won't see a Dana in those pits, anywhere.
I went that way a long time ago and I am still glad I did. Well, something else to ponder.
Re: 8 3/4 vs. Dana 60 [Re: SportF] #2685259
08/07/19 10:03 AM
08/07/19 10:03 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I run a Dana but if I was in a class where frequent gear changes were required I would certainly run something different.
Re: 8 3/4 vs. Dana 60 [Re: 340Cuda] #2688724
08/17/19 12:33 PM
08/17/19 12:33 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
A Dana looks good under anything. Here’s my S60 3.73 gears and a Detroit Locker in my Dart. It’s behind a Passon 5 speed trans. [Linked Image]
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: 8 3/4 vs. Dana 60 [Re: mopardude318] #2688881
08/17/19 08:24 PM
08/17/19 08:24 PM
Kentucky
Kentucky
Dude how nice is that! There are several nice upgrades within the camera lens. Is all that necessary or did you do it just because you wanted too?
Re: 8 3/4 vs. Dana 60 [Re: dfsmopars] #2694298
09/04/19 11:38 AM
09/04/19 11:38 AM
Gilroy,CA.
Gilroy,CA.
Thank you. It's probably not necessary. I mini tubbed and did a spring relocation. Decided on a fuel cell and cut the trunk out and formed a box to hold the cell. Disc brakes are not needed but I wanted them. I made the hard lines, and used off the shelf DOT Russell soft lines going to the calipers. The suspension is Bill's RMS Street Linx, an older setup I bought 10 years ago when I started working on the car. I didn't like the bolt on brackets on the axle, so I ordered a weld on version from him, just to clean it up. When I put a Dana under my other car, (68 Fastback) I'm gonna stick with leaf springs. Seems to make things less complicated. LOL
