Re: So how stout are the 78 440 blocks?
[Re: stinger]
#2683224
07/31/19 09:03 PM
07/31/19 09:03 PM
RapidRobert
wouldn't hurt to do a pressure & sonic check (both). From what I read, the later blocks being thinwall ain't true. there is info in the archives here.
[Re: moparmarks]
#2683508
08/01/19 07:38 PM
08/01/19 07:38 PM
Posts: 6,317 nowhere
Sniper
nowhere
Also larger water jacket ports to the heads. That is somewhat irrelevant as the holes in the head gasket manage flow thru those ports.
[Re: Kern Dog]
#2683619
08/02/19 10:08 AM
08/02/19 10:08 AM
Posts: 31,073 Oregon
AndyF
Either Mopar Muscle or Mopar Action magazine did a test to learn get to the bottom of the rumors. They found that the later blocks were heavier but that the metal was slightly softer than the early blocks. The Warnings that Larry Shephard and other Mopar Performance reps told about late blocks being "Thin Wall" was wrong. It makes me wonder whether these guys were idiots or too lazy to check for themselves before spreading false rumors. I've run later blocks simply due to them being easier to find. I wrote that article for Mopar Action.
[Re: AndyF]
#2683623
08/02/19 10:19 AM
08/02/19 10:19 AM
Posts: 16,840 Between Houston & Galveston TX
SattyNoCar
Either Mopar Muscle or Mopar Action magazine did a test to learn get to the bottom of the rumors. They found that the later blocks were heavier but that the metal was slightly softer than the early blocks. The Warnings that Larry Shephard and other Mopar Performance reps told about late blocks being "Thin Wall" was wrong. It makes me wonder whether these guys were idiots or too lazy to check for themselves before spreading false rumors. I've run later blocks simply due to them being easier to find. I wrote that article for Mopar Action. And the link here at Moparts for that article now goes to a brake upgrade article. " Sonic Checking the Mopar Big Block goes to --- brake-upgrade
John
[Re: Sniper]
#2683665
08/02/19 12:15 PM
08/02/19 12:15 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Also larger water jacket ports to the heads. That is somewhat irrelevant as the holes in the head gasket manage flow thru those ports. True but the 76-8 452 heads also have larger ports so increased flow to the heads may have been a goal.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: AndyF]
#2683802
08/02/19 07:11 PM
08/02/19 07:11 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Either Mopar Muscle or Mopar Action magazine did a test to learn get to the bottom of the rumors. They found that the later blocks were heavier but that the metal was slightly softer than the early blocks. The Warnings that Larry Shephard and other Mopar Performance reps told about late blocks being "Thin Wall" was wrong. It makes me wonder whether these guys were idiots or too lazy to check for themselves before spreading false rumors. I've run later blocks simply due to them being easier to find. I wrote that article for Mopar Action. That was a great one too. Thank you for the research! I notice that you don't toot your own horn although you have accomplished many things.
[Re: SattyNoCar]
#2683807
08/02/19 07:49 PM
08/02/19 07:49 PM
AndyF
Either Mopar Muscle or Mopar Action magazine did a test to learn get to the bottom of the rumors. They found that the later blocks were heavier but that the metal was slightly softer than the early blocks. The Warnings that Larry Shephard and other Mopar Performance reps told about late blocks being "Thin Wall" was wrong. It makes me wonder whether these guys were idiots or too lazy to check for themselves before spreading false rumors. I've run later blocks simply due to them being easier to find. I wrote that article for Mopar Action. And the link here at Moparts for that article now goes to a brake upgrade article. " Sonic Checking the Mopar Big Block goes to --- brake-upgrade That doesn't surprise me. A few years back a whole bunch of the links got broken and moved around during one of the upgrades. Most of the older articles were lost. Guess they disappeared into the internet black hole.
