what clutch to buy for bb 500hp #268245
03/27/09 12:37 PM
03/27/09 12:37 PM
kewaskum wi
trend setters Offline OP
kewaskum wi
Hey guys rebuilding my 4-spped and wondering what clutch to buy? motor is about 500 hp but I am going to build a stroker and don't want to buy another clutch at that time. I herd people are using viper clutches ?
Re: what clutch to buy for bb 500hp [Re: trend setters] #268246
03/27/09 12:40 PM
03/27/09 12:40 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
I think most refer to the viper clutch as the 11.95" McLeod that will work on the 11" wheel. What bell/flywheel are you using?
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: what clutch to buy for bb 500hp [Re: 64dodge572] #268247
03/27/09 12:45 PM
03/27/09 12:45 PM
kewaskum wi
kewaskum wi
11" flywheel and a scater sheild. I have always run a center force clutch but I am very hard on clutches and looking for the best bang for the buck.
Re: what clutch to buy for bb 500hp [Re: trend setters] #268248
03/27/09 01:16 PM
03/27/09 01:16 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Holding 500 hp will be no problem with a 11.95" McLeod set-up. Do you have a 23 or 18 spline trans? If you want some pricing I have some listed on the web, or you can give Wayne a call here at the shop.
Dan
FAX 937-947-4419
Re: what clutch to buy for bb 500hp [Re: 64dodge572] #268249
03/27/09 01:22 PM
03/27/09 01:22 PM
kewaskum wi
kewaskum wi
23 spline thanks
Re: what clutch to buy for bb 500hp [Re: trend setters] #268250
03/27/09 02:29 PM
03/27/09 02:29 PM
roanoke va
kbcuda Offline
kbcuda  Offline
roanoke va
Mcleod dual disk.....
Re: what clutch to buy for bb 500hp [Re: kbcuda] #268251
03/27/09 03:51 PM
03/27/09 03:51 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Mcleod street twin but they are pricey. I am on my 3rd clutch in 6 yrs. and wish I bought a street twin but I can't afford $900 on a clutch.
http://www.mcleodind.com/application_guide_pgs/STREET_TWINS_mopar.html
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: what clutch to buy for bb 500hp [Re: 70sixpkrt] #268252
03/27/09 04:07 PM
03/27/09 04:07 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I bought a $700 McLeod RST Dual Disc. The best clutch for a street strip car under 800hp. Lightest pedal ever. I've been praising them since I put it in, so I won't bore everyone, but I'm impressed by it. I'm glad I spent what I did and not 1/2 for a Centerforce. The pedal feel alone is worth it.
Re: what clutch to buy for bb 500hp [Re: LAR_414] #268253
03/27/09 04:15 PM
03/27/09 04:15 PM
70sixpkrt Offline
70sixpkrt  Offline
What's the difference between the RST Dual Disc compared to the Street Twin?
4-speed
3:54 Dana
