1961 Plymouth Fury brake upgrade? #2682328
07/29/19 12:13 PM
07/29/19 12:13 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Hey guys, I have a customers 1961 Fury, really nice original car for it's age and condition, I'm looking to do some "upgrades", the first and foremost is the brake system, mainly the master, this is the single line/single pot master unit, (non-power) looking to upgrade the master to a more traditional Mopar 70's style dual line/reservoir (manual) drum/drum master, while I could engineer/machine/fabricate the needed pieces, I'd much rather "cut to the chase" and see what others may have done/employed for an upgrade in this department?.... originality is a non issue here, safety is the primary factor, I'm even open to using brand X parts to get the job done..
Any help is appreciated,
Mike
Re: 1961 Plymouth Fury brake upgrade? [Re: DAYCLONA] #2682393
07/29/19 03:14 PM
07/29/19 03:14 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If all you are doing is updating the MC then stick with factory stuff. Get a later dual reservoir manual MC and it'll bolt on.
You'll likely need a T splitter to tie both the front lines to the rear port and add a bit of hard line to tie the rear brakes to the front port. I suppose you could run a factory splitter from a later all drum setup as well, CI sells one new.
That's exactly how I update my 64 Chrysler to dual reservoir, though in my case it was a power setup.
Re: 1961 Plymouth Fury brake upgrade? [Re: Sniper] #2682426
07/29/19 04:34 PM
07/29/19 04:34 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Thanks! pretty much what I plan, just wondering on the pedal rod/linkage compatibility with a 70's style dual/drum/drum master, might also consider a front disc conversion if the customer is interested?
Mike
Re: 1961 Plymouth Fury brake upgrade? [Re: DAYCLONA] #2682437
07/29/19 04:51 PM
07/29/19 04:51 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I have not found pedal rod/linkage compatibility to be an issue, but I am not a B body guy.
I just reuse the rod from the original application in the replacement MC, though finding that little rubber bushing is hit or miss these days.
IIRC, the retaining groove in the piston for that bushing is located in the same spot in relation to the M/C mounting face single or dual pot, a quick check with a dial caliper will confirm that.
Reusing the original rod takes care of any length issues there and the pedal ratio is the same so you should be good.
Re: 1961 Plymouth Fury brake upgrade? [Re: Sniper] #2682442
07/29/19 05:06 PM
07/29/19 05:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most of the FL cars didn't have the rubber push rod retainer bushing, they have a positive pedal up stop. The push rod is adjustable for length so just adjust it for .020" free play at the MC.
Re: 1961 Plymouth Fury brake upgrade? [Re: John_Kunkel] #2682445
07/29/19 05:14 PM
07/29/19 05:14 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
FL cars?
Never found an adjustable pushrod in a manual car, but then again, never fooled with a 61 Fury either.
Re: 1961 Plymouth Fury brake upgrade? [Re: Sniper] #2682446
07/29/19 05:15 PM
07/29/19 05:15 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
FL = Forward Look
Re: 1961 Plymouth Fury brake upgrade? [Re: 6bblgt] #2682459
07/29/19 05:40 PM
07/29/19 05:40 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Did '61s still use the double-leading-shoe design like '57-'58 ?
Might want to look at that too, if you're the guy that has to service the car in the future.
I've been told they're a bear to work on & require some specialized tools, but the guys on the FL site may debunk that.
If it was mine, I'd be strongly tempted to swap on discs or at least later & bigger brakes.
(Gee, I wonder why all my stuff turns into a major project? laugh2)
Re: 1961 Plymouth Fury brake upgrade? [Re: topside] #2682488
07/29/19 07:08 PM
07/29/19 07:08 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Link for front discs
https://scarebird.com/index.php?route=product/product&path=64&product_id=54
You can also buy an adjustable rod, which I’d recommend since you are going off the map a bit.
Re: 1961 Plymouth Fury brake upgrade? [Re: Montclaire] #2682617
07/30/19 09:10 AM
07/30/19 09:10 AM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Thanks Guys!, really appreciate the insight/info pointing me in the right direction
Mike
Re: 1961 Plymouth Fury brake upgrade? [Re: DAYCLONA] #2682744
07/30/19 04:03 PM
07/30/19 04:03 PM
Canada
demon Offline
demon  Offline
Canada
Mike
60-64 full size Mopars are easy to upgrade. The F, M, J body disc brake spindles etc will bolt right on. Grab an old Diplomat or 5thAve and swap it all over.
On my 61 Plymouth, I used 64 Chrysler spindles and 11x3 drums on the front, added the sway bar too, used a 69 Raid Runner 83/4 with 11x2 1/2 brakes and a 67 up dual master cyl. Total bolt on and stops great.
Any 65-69 C body diff will bolt right in
Re: 1961 Plymouth Fury brake upgrade? [Re: demon] #2683019
07/31/19 10:10 AM
07/31/19 10:10 AM
moparx Offline
moparx  Offline
i used a diplomat cop car spindle and disc setup on a 64 300 one time. worked like a champ !
i also used the diplomat swaybar that clamps to the strut rods with a little extra bending at the factory bend. made a big improvement.
the screw in lower balljoints are also the same as the 77-89 diplomats, K719. [57-61 fury]
beer
Re: 1961 Plymouth Fury brake upgrade? [Re: Sniper] #2683092
07/31/19 12:54 PM
07/31/19 12:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
FL cars?
Well, shoulda said some of instead of most of.
