We got the car running and driving but have noticed that when coasting to a stop in neutral the engine will die. Its a factory throttle body with a harness and computer from hotwire auto, they said that there is no idle control that can be adjusted like a LS engine and that some people start by drilling a small hole and keep up sizing it until it will let enough air through while the throttle blade is closed. Has anyone else experienced this problem? thanks
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
