Plugs for RB Indy EZ heads #2680851
07/24/19 10:19 AM
07/24/19 10:19 AM
michigan
challenged448 Offline OP
michigan
What plugs are you using RB Indy EZ heads hyd roller
Re: Plugs for RB Indy EZ heads [Re: challenged448] #2680873
07/24/19 11:03 AM
07/24/19 11:03 AM
AndyF Offline
AndyF  Offline
Depends on compression ratio. I use NGK street plugs for street cars, race plugs for race cars.
Re: Plugs for RB Indy EZ heads [Re: AndyF] #2680880
07/24/19 11:38 AM
07/24/19 11:38 AM
michigan
michigan
11 to 1 have ngk r5671a-8 street driven breaking it in they look cold to me
Re: Plugs for RB Indy EZ heads [Re: challenged448] #2680912
07/24/19 01:29 PM
07/24/19 01:29 PM
Cab_Burge Online work
Cab_Burge  Online Work
Look at the Autolite 3923 for your motor, try them first and if they seem to cold try the next hotter step 3924. I like and use Champions also, thier RC9YC would work well in your motor also shruggy
NGK brand work well also and may be available at your local part stores scope
Re: Plugs for RB Indy EZ heads [Re: Cab_Burge] #2681010
07/24/19 06:42 PM
07/24/19 06:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Race plugs aren’t great on the street.
Try an NGK BCP7ES
Re: Plugs for RB Indy EZ heads [Re: fast68plymouth] #2681310
07/25/19 03:52 PM
07/25/19 03:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am running the NGK R5671A-7 in my street/strip car. That's the plug Indy recommended I run with my 10.6 comp and EZ heads. Ron
