0.020" under SB connecting rod bearing - suggestions? #2680711
07/23/19 10:07 PM
07/23/19 10:07 PM
Windsor, ON, Canada
Diplomat360 Offline OP
Windsor, ON, Canada
Well, I finally got a response from the King Bearings folks. The 0.020" under connecting rod bearings (CR805XPN020) which I ordered waaaaayyyy back on May-14th, and which have now gone through at least three separate shipping delays (ordered at Summit) aren't even scheduled to be made, for quite some time, as in:
Quote
We are currently out of stock on this part and I don't see then going into production anytime soon.
Regards,
Daniel McDermott
Technical Support Representative
King Engine Bearings
Tel: 973 857 0705 x309
Fax: 973 857 3228
Toll-free: 800 772 3670 x309
www.kingbearings.com
www.kingracebearings.com
So now I'm somewhat stuck here given that the block ('74 360 casting) is at the machine shop along with all the other parts. The crank is a 0.020" under, forged piece with a fillet, the con rod journals are 2.1040-2.1041. The only undersize bearings I find are stock replacement pieces, which I am not thrilled about using in my build (408 W2 stroker motor).
Any suggestions on what else I could try here?
I thought of maybe cutting the crank another 0.004" to get me to the high-end of the Chevy small block (350) journal size (1.9990 - 2.1000), plenty of choices there, but not crazy about machining the crank.
Is there anything else out there that I could try? Any other stock or even 0.010" under journals in other engines that would get me the equivalent of my 0.020" under, which is 2.1040?
Thanks everyone!
EDIT
My current motor has a SealedPower 0.010" under CP-series bearing, haven't taken it apart yet, but no complaints so far. They do make a 0.020" under as well => 82130CP20
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: Diplomat360] #2680715
07/23/19 10:13 PM
07/23/19 10:13 PM
Washington
madscientist Offline
Washington
This won't help you much, but this is why I quit using Chrysler bearings years ago. I turn down every crank to LJ SBC to start with and use Chevy rods. It's easier.
In your case I'd use whatever bearing you can get. IMO the bearing brand is not an issue.
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: Diplomat360] #2680972
07/24/19 04:32 PM
07/24/19 04:32 PM
Andrews,In. U.S.of A.
67_Satellite Offline
You have a P.M.
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: Diplomat360] #2680984
07/24/19 04:50 PM
07/24/19 04:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is this a race engine... I went with stock bearings due to the fact
your not gonna spin it really hard.. I turn my 416 to about 7000 rpms..
I didnt think I would be turning it that high but I do .. this is in my
street rod with a solid cam... I did have to cut the bearings being that
the crank has a radius to clear(no big deal)
wave
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: MR_P_BODY] #2680994
07/24/19 05:27 PM
07/24/19 05:27 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I will have some with me at Norwalk this weekend if you are coming or have a friend.
Todd@ Marsh Performance. I might have some narrow ones as well but I would have to look.
Todd
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: MR_P_BODY] #2680995
07/24/19 05:32 PM
07/24/19 05:32 PM
Windsor, ON, Canada
Windsor, ON, Canada
wave
Nah, not a race engine at all...in fact this will be 90% street run and should top out at 6500.
So how does one actually cut these bearings? I assume a machine shop operation, keep in mind a DIY is fine with me provided that I do not need special tools.
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: sasquatch] #2680997
07/24/19 05:42 PM
07/24/19 05:42 PM
Windsor, ON, Canada
Windsor, ON, Canada
Hi Todd,
Todd
Nah, wish I could, but no-go. If you get a chance, sure thing please let me know if you have something already narrow enough to make this work.
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: Diplomat360] #2681013
07/24/19 06:55 PM
07/24/19 06:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just use a fine file.. or my die grinder with a fine bit.. doesnt take
much... just try a 45* angle
wave
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: MR_P_BODY] #2681024
07/24/19 08:24 PM
07/24/19 08:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
i"ll be at Norwalk this weekend. If you want the parts Todd has I can bring them back to the Detroit metro area if you would like.
Doug
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: dvw] #2681029
07/24/19 08:46 PM
07/24/19 08:46 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I know I have the CB 481 P20 s on the trailer that is already packed and I think I might have some CB 481H .020. They make a tool called a bearing knife for trimming the sides but any good utility knife will work. Bearings are not near as hard as you might think.
Todd
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: sasquatch] #2681060
07/24/19 10:57 PM
07/24/19 10:57 PM
Windsor, ON, Canada
Windsor, ON, Canada
Todd,
I think the CB481H does not come in 0.020" under...at least today's catalog lists no such thing. All of it is either std or 0.010 at most. But if you have that golden nugget I'd happily take you up on this, let me know the costs please and what would be the best way for me to get you that payment. I'm leaving on a canoe trip vacation with my daughter this Sunday, so forgive me please if I go silent after that (northern Ontario, cell reception IS spotty).
In the name of full disclosure: 67_Satellite has offered to send me his old and un-used CB-481P 0.020" set (free of charge to boot, although I'd feel way more comfy at least coughing up for the shipping costs...ahem, are you reading this Mr.Satellite???)!
Note that the CB481H is supposed to be a performance bearing with the chamfer already in-place, so if you trully have one that's 0.020" under that be the way to go.
dvw,
If Todd does find that matching CB481H bearing I would greatly appreciate it if you can pick that up for me.
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: Diplomat360] #2681064
07/24/19 11:05 PM
07/24/19 11:05 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
OK
I went and looked.
I for sure have the CB481P 020 but not the H series. Ironically I do have some CB481H in a .30 under. I got into a warehouse closing and I am sure these are older stock. Still new in the package and as far as bearings go old is gold in my book.
Todd
Re: 0.020" under SB connecting rod bearing - suggestions? [Re: sasquatch] #2681764
07/27/19 09:55 AM
07/27/19 09:55 AM
Windsor, ON, Canada
Windsor, ON, Canada
Todd and dvw,
OK
I went and looked.
I for sure have the CB481P 020 but not the H series. Ironically I do have some CB481H in a .30 under...
Todd
Thank you for looking into this. Since I already have the CB481P bearings coming my way it makes no sense to get another set. You are right, the 0.030" is ironic sizing, and to do that I would have to re-gring the crank at which point in time I really should aim for the 2.100" journal size instead and open up the selection to a massive list of bearings.
Gentlemen, thank you again, I appreciate your help but I will pass up on the opportunity at this point in time.
