New distributor needed #2679315
07/20/19 07:26 AM
07/20/19 07:26 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Who makes the best electronic ignition distributor that has a feature that I can set my total advance. I need more initial timing but less total in this combination.
Re: New distributor needed [Re: fastmark] #2679351
07/20/19 10:02 AM
07/20/19 10:02 AM
I would suggest haveing your welder weld up/shorten the slots in the cam plate then file em open to get the amt you want & there's the FBO plate tho people have complained that the too large center hole lets the plate shift changing the amt (no opinion/exp with that) & the hole ID could be reduced. If you have an early 70's (non Mallory based) dist that is what I would do. For a recommendation for a dist here is a BTT for ya.
Re: New distributor needed [Re: RapidRobert] #2679357
07/20/19 10:20 AM
07/20/19 10:20 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I use a MSD dist and bought this.
https://www.ebay.com/i/222896913875
Re: New distributor needed [Re: fastmark] #2679386
07/20/19 11:14 AM
07/20/19 11:14 AM
AndyF Offline
AndyF  Offline
The last generation MP distributor was a good design with the plastic keys for setting advance. That design had a lot of adjustability but you had to take it all apart to make changes. The MSD pro billet has some adjustability but not a ton. Out of the box it is limited to 16 degrees of advance so you can run 20 initial and 36 total. I eventually gave up on mechanical distributors and switched to digital just because of these issues.
Re: New distributor needed [Re: AndyF] #2679509
07/20/19 06:11 PM
07/20/19 06:11 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The one distributor I'd love to have was the short-lived Crane model that had a programmable vacuum advance feature. I went into sticker shock when they first came out, and by the time I was willing to consider one seriously, Crane was in major financial trouble and that series of their distributor line got the axe. Never found one listed anywhere since then, so it's possible there were none actually produced, either.
Re: New distributor needed [Re: BradH] #2679510
07/20/19 06:15 PM
07/20/19 06:15 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: New distributor needed [Re: 70AARcuda] #2679815
07/21/19 04:50 PM
07/21/19 04:50 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Firecore dist have adjustable plates. You do not need to take apart dist to adjust. You would need to take it apart if you wanted to change springs. Msd dist are crap
Re: New distributor needed [Re: AndyF] #2679844
07/21/19 07:02 PM
07/21/19 07:02 PM
Quote
Andy I was under the impression that there was a flaw in those Mallory based ones that was a pain (maybe something Ehrenberg said). Am I off base on that? If it is just that you gotta dig into em to rework em, well that's what we do.
Re: New distributor needed [Re: RapidRobert] #2679865
07/21/19 08:11 PM
07/21/19 08:11 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
My fire core didn't last a season before it was junk. I'd go msd.
Re: New distributor needed [Re: DblOJoe] #2679882
07/21/19 08:58 PM
07/21/19 08:58 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
So what went bad on it?
Re: New distributor needed [Re: fastmark] #2679885
07/21/19 09:25 PM
07/21/19 09:25 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I never had any problems with my MSD dist. It has been on my car for 10 years.
Re: New distributor needed [Re: fastmark] #2679887
07/21/19 09:33 PM
07/21/19 09:33 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
The plate for the mechanical advance broke. It advanced the timing even though it was locked out.
Re: New distributor needed [Re: DblOJoe] #2679888
07/21/19 09:36 PM
07/21/19 09:36 PM
Aurora, Oh.
max_maniac Online happy
max_maniac  Online Happy
Aurora, Oh.
I agree ---- I went through 3 of them. Go MSD!!!!
Re: New distributor needed [Re: mopars4ever] #2679889
07/21/19 09:38 PM
07/21/19 09:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The Firecores are adjustable. I like that feature as the Hemi doesn't like a lot of advance...Its tough if you want to make precision adjustments...
And for the record, my Firecore coil quit in less than a year...The distributor is still going though.
Re: New distributor needed [Re: Dragula] #2679908
07/21/19 10:38 PM
07/21/19 10:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
On my 512 I wanted vac advance for street use. Had a Firecore which was OK but didn't have vac.
Went with an FBO-reworked MP distributor with their plate in it & set for 20 initial, 36 total.
Perfect, lit right off cold or warm, zero issues, spot on.
Re: New distributor needed [Re: Dragula] #2679989
07/22/19 08:03 AM
07/22/19 08:03 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks guys. This is the kind of info I need. Anyone used the complete FBO distributor they sell?
Re: New distributor needed [Re: topside] #2680036
07/22/19 10:23 AM
07/22/19 10:23 AM
Dragula Offline
Dragula  Offline
Do you think they could set one up for say 23 initial and 31 total? My car likes all the timing it can get at an idle...I tried a locked distributor with a retard...it never worked on the first try...Was going to break a starter or worse.
Re: New distributor needed [Re: Dragula] #2680044
07/22/19 10:51 AM
07/22/19 10:51 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Ok, here is the trick. On the mopar, fbo or firecore dist. Take dist apart. Run just one light spring. One. Not 2. Set up your timing wherever it starts best. As soon as it fires it will go full advance. You cant do this trick on the msd's unless you do some work to hold the weights because they are held in place by the springs( that will eventually rust away, lol)
Re: New distributor needed [Re: fastmark] #2680045
07/22/19 10:56 AM
07/22/19 10:56 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I have run a fbo dist and box years ago. Worked great. Never a problem. Went 10.50s at over 3700lbs and drove the car all the time. Hpwever, when I finally put a msd 6 on my car, there was a noticeably better idle, air fuel went leaner under 3000 rpm which told me that those boxes really work
Re: New distributor needed [Re: fastmark] #2680079
07/22/19 12:23 PM
07/22/19 12:23 PM
BradH Offline
BradH  Offline
... Anyone used the complete FBO distributor they sell?
I was looking at those last night (the new HR-series billet ones, not the Pertronix or earlier cast-body FBO deals) and was going to ask the same question.
