Speedo gear 32 vs 31 tooth
#2679829
07/21/19 06:35 PM
07/21/19 06:35 PM
Posts: 20,887 A collage of whims
topside
A collage of whims
According to Brewer's, I need a 31 tooth for 3.23s & 28" tire According to the Interweb, a 32-tooth. I have a mint 32, a mint 39, and a used 31 with a few teeth knocked off, of course What's 1 tooth worth in MPH on this setup? FWIW, I tend to drive by the tach on the highway, but around town I'd like to know my speed.
Re: Speedo gear 32 vs 31 tooth
[Re: topside]
#2679834
07/21/19 06:50 PM
07/21/19 06:50 PM
RapidRobert
I'd want the mint 32 toother in there just cuz how bad the 31 toother is but it'd show the MPH a hair low than actual MPH (might cost you a ticket, might not). The archives has a chart & someone posted a link for a comprehensive chart but I dont have that info. EDIT measure your actual tire dia to get it as dead on as possible (might change what tooth count you need). MORE EDIT the chart someone posted had a MPH/RPM chart that was very helpful & there was something about an Excel worksheet. EVEN MORE EDIT the Excel worksheet in the 2 links are right there on the same page, right in front of me, I missed it.
[Re: topside]
#2679974
07/22/19 04:57 AM
07/22/19 04:57 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
There is an XLS table on tech section here where makes the exact maths. You could get maybe a 31,45 result. So you decide which one is the best for you based on that ( rounding up or not )
[Re: Mr340]
#2680033
07/22/19 10:14 AM
07/22/19 10:14 AM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I recently went from a 28 to a 29 and the speedo went from 4mph low to 3mph high. this was with a 2.76 and 26" tires and a 4 speed. Maybe go up a tire size or 2 to get it dead nuts. Kevin
[Re: Twostick]
#2680035
07/22/19 10:19 AM
07/22/19 10:19 AM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
I recently went from a 28 to a 29 and the speedo went from 4mph low to 3mph high. this was with a 2.76 and 26" tires and a 4 speed. Maybe go up a tire size or 2 to get it dead nuts. Kevin I usually drive 5-7 over so the 3 hi gives me an extra cushion
[Re: topside]
#2680039
07/22/19 10:30 AM
07/22/19 10:30 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
IIRC, when I did the arithmetic years and years ago, each tooth was worth ~ 1.67%. Which meant you should be able to get it within 1% either way +/- if your speedo head is working correctly. FWIW, YMMV, ect. 2¢
Roibert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
