99 ram 1500 front shock replacement #2679812
07/21/19 04:41 PM
07/21/19 04:41 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
Have a 99 ram 1500 4wheel drive.going to change the front shocks but the 3 nuts are rusty on the shock towers .Can the bolts be replaced if I cut them off?
Re: 99 ram 1500 front shock replacement [Re: 3wracing] #2680492
07/23/19 02:11 PM
07/23/19 02:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
They are studs. I would heat the nuts to remove them. Then just replace the nuts.
Re: 99 ram 1500 front shock replacement [Re: NITROUSN] #2680597
07/23/19 05:12 PM
07/23/19 05:12 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
thankyou
Re: 99 ram 1500 front shock replacement [Re: 3wracing] #2680599
07/23/19 05:21 PM
07/23/19 05:21 PM
md
mopars4ever Offline
mopars4ever  Offline
md
heat them and hit them with some candle wax when hot
