Re: Earlier 340 Internals in 1973 318's
[Re: elmor353]
#2679808
07/21/19 04:29 PM
07/21/19 04:29 PM
Posts: 6,295 nowhere
Sniper
nowhere
Also, weren't the 273, 318 and 340 cranks and rods the same? no
[Re: Sniper]
#2679810
07/21/19 04:34 PM
07/21/19 04:34 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Well, some stuff swaps over, bolts, timing covers, brackets, oil pans, etc.
But.........
Do not believe everything you read on the internet or elsewhere.
At times, skepticism is a virtue.
[Re: elmor353]
#2679840
07/21/19 06:56 PM
07/21/19 06:56 PM
RapidRobert
What Mopars4ever said on the receipts/balancing, go check it out skeptically, it may be a good deal (nothing ventured nothing gained). EDIT if parts were swapped I would assume it was balanced).
[Re: mopars4ever]
#2679849
07/21/19 07:07 PM
07/21/19 07:07 PM
Posts: 302 Ontario, Canada
GVH
Ontario, Canada
rod # 3418645 was used in 73/74 318 same rod 71/73 360 and also 72/73 340 with cast crank . Non of the 318 & 340 cranks have the same part #'s
[Re: GVH]
#2679851
07/21/19 07:20 PM
07/21/19 07:20 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
The forging part numbers might be the same but the finished part numbers wouldn't be. IIRC 318's and other small blocks had a pressed wrist pin, whereas 340 rods all were bronze bushed and the pistons had floating pins with C Clips.
[Re: 500ciDuster]
#2679896
07/21/19 10:10 PM
07/21/19 10:10 PM
Porter67
Looks like seller corrected his listing. The power steering pump might be a good grab. https://portland.craigslist.org/mlt/pts/d/sherwood-mopar-318-la-long-block/6938547508.htmlWas...Nearly complete 73’ dated Mopar 318 LA motor with all accessories pictured! Would be a good core motor to rebuild. 1973 is when Mopar started putting the earlier 340 engine internals into their 318 motors. This makes for a great rebuild or stroker! It has a Now..Nearly complete 73’ dated Mopar 318 LA motor with all accessories pictured! Would be a good core. This makes for a great rebuild or stroker! I have never ran engine so it should be rebuilt before use. Sold as core. Read Less
[Re: Cab_Burge]
#2680088
07/22/19 12:59 PM
07/22/19 12:59 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I bought a 70 318 once for a core with a rod knock for the forged crank, opened it up and it had 4.070 bore TRW forged 340 pistons in it. I still have the block under my shelf as the bores still look great, I just can't convinve myself to put it back together seeing how the normally 165 # block now weighs 122# and the bores sound like glass when I tap on them with my fingernail.
[Re: GVH]
#2680625
07/23/19 06:11 PM
07/23/19 06:11 PM
Sixpak
The Swamp
source i have says 273 /318 and all 340 up to 73 had floating pins . 318 went to pressed pins in 74 and all 360 had pressed pins . I thought the only motors of that era to get bronzed bushed rods and floating pins were the 340 and the Gen 2 hemi...
