I need to limit my advance on this car I’m working on and this appears to be an option. I was looking at the complete kit with the ECU because this customer already has a factory mopar ecu on on his car. Does it have a cover on the back or is it open like the pictures? I was afraid it might get wet if it had no back on it. Does anyone here use this system and like it? I have heard that the center hole of the limiting plate is too big so it allows the timing to jump a bit.
I have the kit on my 73 Charger. The kit works great, I haven't put the limiting plate in as of yet. I don't recall it having a cover on the back, not worried about it getting wet though as the factory one I tool off didn't have a back either. I had an ignition issue causing the car to not run, i bought a reman distributor from a guy on FBBO and this kit and there was no longer an issue with the car running. I actually think the distributor was the problem but I can't prove it.
If you want I can pull the box off and look, it's at the firehouse with me today.
