Durango transmission swap #2679053
07/19/19 11:33 AM
07/19/19 11:33 AM
Omaha, Nebraska
Scott Carl Offline OP
Omaha, Nebraska
I have an 03 Durango 4.7 with a bad engine. (bad rod bearing) Found another 03 with a 5.9 and a bad transmission. (rear piston broke) Are the transmissions interchangeable? OR on the rear piston issue: can this be fix in the vehicle?
Thanks,
Scott
Re: Durango transmission swap [Re: Scott Carl] #2679850
07/21/19 07:09 PM
07/21/19 07:09 PM
Omaha, Nebraska
Omaha, Nebraska
No Trans people?
Re: Durango transmission swap [Re: Scott Carl] #2679859
07/21/19 07:50 PM
07/21/19 07:50 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I think the transmissions are different from each other, and I would fix the 4.7 if it were me.
Re: Durango transmission swap [Re: buildanother] #2679862
07/21/19 08:02 PM
07/21/19 08:02 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The transmissions are different between the 5.9 and the 4.7. The wiring harness and computer are also different between the two drivetrains, and if the 4.7 is anything like the 5.7 as far as motor mounts, they are also different between the 5.9 and the 5.7.
We swapped a 5.7 into an old car that had a 5.9 and we had to change everything, nothing interchanged. Gene
Re: Durango transmission swap [Re: Scott Carl] #2679985
07/22/19 07:38 AM
07/22/19 07:38 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I'd drop a 5.7 in the 4.7 truck if you want to keep it. One of the Dakota guys did that swap years ago and the 4.7 computer ran the 5.7 fairly well.
- Stu Harmon
