Re: Mopar distributor nylon shaft collar
[Re: Lee446]
#2678822
07/18/19 07:15 PM
07/18/19 07:15 PM
RapidRobert
Yes get a generic collar which will be tighter radially than the OE collar (unless you want it 100% OE). While you are at it reduce the axial clearance to .005" & speedway mtrs has a kit of flat washers for dirt cheap ($4.99 iirc + the ride).
[Re: gzig5]
#2679198
07/19/19 07:37 PM
07/19/19 07:37 PM
Posts: 4,694 Wichita
GY3
Wichita
Hillman makes nylon collars that are available at Lowes. I've rebuilt quite a few distributors with them and they work perfect. .99 for two last I checked..
[Re: GY3]
#2679477
07/20/19 03:53 PM
07/20/19 03:53 PM
Posts: 1,674 California
biggE
California
Hillman makes nylon collars that are available at Lowes. I've rebuilt quite a few distributors with them and they work perfect. .99 for two last I checked.. Great tip! I just went and bought a few of the two packs at Lowes. The only difference was in CA they are $1.54 per pack plus tax. Typical extra charge for just breathing the air here.
[Re: biggE]
#2679480
07/20/19 04:21 PM
07/20/19 04:21 PM
GY3
Wichita
Hillman makes nylon collars that are available at Lowes. I've rebuilt quite a few distributors with them and they work perfect. .99 for two last I checked.. Great tip! I just went and bought a few of the two packs at Lowes. The only difference was in CA they are $1.54 per pack plus tax. Typical extra charge for just breathing the air here. They have the roll pins too in a Hillman pack. Can you post up the part number for the collars? I went looking last night and couldn't find my stash..
[Re: mopars4ever]
#2679720
07/21/19 12:04 PM
07/21/19 12:04 PM
GY3
Wichita
I wonder how well they do with the engine temps? I assume the quality is there? The last one I used has been in the engine for 5700 hard miles and hundreds of dragstrip passes. It has been over 210 a couple of times but never "overheated".
