rear wheel offset clarification
#267844
03/26/09 11:40 PM
03/26/09 11:40 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
i've read the archives,just want to double check before ordering new wheels.current wheels when mounted came right up against outer wheel lip,so i want to move the wheel in,taking tire off rim(rim measures 11" high when laying on bench),put a level across the back,measured from the bottom of the level to the back of the rim(part that sits against the brake drum=3 7/8",so to move the outside of the tire closer to the inner fender well and away from outer lip about 1" i would want this measurement to be 5" back space,so i would order a 15"x10" by 5"? is this right? 70 runner and 70's s/s crager rims. thanks you and hope this makes sense.
